But never yours!One new feature you might have missed is the ability to ignore a user's posts.
The sticky post styling is really nice
I missed it, but don't understand the problem.@thiggins Did you see my post #62? Am I doing something wrong?
Thanks Tim. My post is here and OzardEdge confirmed it here.I missed it, but don't understand the problem.
Please send a link to your post that shows the problem.
Thanks Tim, that makes sense now. I guess it was never an issue before because the links I posted were never unfurled.The problem appears to be with Xenforo's new way of handling links. This post may help explain.
XF 2.1 - Links to posts in the same forum are unfurling the wrong post - the first on the page
We have a problem where links to posts within our forum are unfurling to show show the first post on the page instead of the correct post. They do, however, link to the correct post. If I change the admin setting for the number of messages on the page (from the usual 25 to 26), the existing...xenforo.com
In your post above, I toggled the editor to BBcode and removed unfurl="true" from the BB code.
Automatic "unfurling" is a setting that can be changed so that pasted links will be pasted the old way. Or you can just do the edit I did.
Nope, not at all. I dig the look - it seems to "pop" better by my eye.
I could see using a feint blue or blue/gray background to better match the overall color scheme. The current color beige/yellow highlights the sticky posts well enough but its not very pleasing color-wise... here.
OE
I noticed off to the left, information about the poster is no longer showing (like number of posts, location).
I'll look into it, but it's unlikely.I posted in the suggestions forums but then found this so I’ll add all thoughts here...
Ideally re enable Tapatalk, but if you insist on not then please resolve;
Add Push notifications
Coming soon.Add Dark Mode support (should be 3 shades of grey only - current theme is not only too light but too busy)
To my knowledge, this is not a Xenforo feature.Fix Autocorrect/Autocapitalise/Autocomplete
These things will change with a new template. I'm not going to put a lot of effort into tweaking things like this.Reduce the size of the username banner on each post - it’s way too tall (borders in general could all be reduced, around quoted text etc for example)
Unlikely.Add/Fix Individual notifications read/unread - right now you click the bell and it clears them all, I want them to remain highlighted in that menu until I’ve clicked/visited each of them
And auto correct etc is still messed up for me!
Only does it on this website. All other apps/sites it’s working fine. I’m assuming there is some JavaScript telling the browser to change the way autocorrect behaves.Auto-correction is a browser/keyboard feature, not a forum feature. Check your settings there. If it doesn't happen with Tim's iPhone, then there must be something different in your settings.
Typing stuff here. And still typing more stuff with lots of deliberate mistakes and it seems to be working correctly. Blah, blah, blah. Words and stuff. This is on my Samsung phone with their browser.I tried doing a post with my iPhone and had no problem with either auto-cap or auto-correct.
Thread starter | Title | Forum | Replies | Date |
Add dedicated sub-forum for GLiNET routers | Suggestion Box | 9 |
Welcome To SNBForums
