loveleeyoungae
EDIT 11th Dec: However, today I tried flashing older stock and Merlin firmwares, 3 versions of each type, all are 384 codebase. And I can now confirm that the issue is only on Merlin firmwares.
There's this infamous issue of USB sticks plugged in USB 3.0 port that has been mentioned here many times: When a USB stick is not detected, it is tricky to make the router detect it again. A normal procedure of rebooting router/re-plugging the USB stick wouldn't work. Even when everything is working normally, a normal reboot will always make the USB stick undetected. No icon in the Network Map webgui, not listed in the fdisk -l command in terminal. The only method is:
a. Power off the router and unplug the USB stick
b. Power on the router and wait for it to boot completely
c. Plug the USB stick
EDIT: Forgot to mention, changing to USB 2.0 mode/port also works, obviously.
My experience with this issue has been with Merlin 384.x versions, never had the chance to try on stock firmwares or 380.xx versions. So, as the new stock firmware 45149 was released several days ago, I thought of trying that. And it turned out my USB stick was always detected properly on this firmware, always showed up after every reboot. I then tried with 384.8_2, and the issue came back. So:
1. Is it reasonable to say that the issue is only in Merlin fw and should we suggest RMerlin to have a look at it?
2. My "My Passport Ultra" Western Digital portable hdd has always been detected properly (even with add-ons installed - entware, Diversion etc...), which made me think the issue only occurs with USB sticks/flash drives? My USB stick is a SanDisk Ultra Flair USB 3.0 Flash Drive.
EDIT: I've just read the thread talking about unmounting script doesn't work properly which may be related to this issue. However, for the tests, I didn't install anything on the USB stick, and the router was always flashed and reset to defaults.
