Davidncali001
What I am about to explain in detail was discovered after I installed the latest beta 2 firmware from Merlin and directly after I uninstalled a Windows 10 VPN client called CyberGhost. So updated Merlin, then immediately uninstalled CyberGhost VPN Windows 10 client.
I discovered a network adapter on my PC and the name was called Incoming Connections. Mind you I have never seen this before. I double clicked it and it said no clients connected. Did some research and found out it's for letting people connect to your PC over the internet. I uninstalled that network adapter and decided to make sure my router hadn't been compromised.
So everything on the router looked like the setting I had originally setup. I did then run the netstat utility inside asus merlin and found a bunch of very odd entries that in all my years of using the Merlin firmware have never seen. I will list all the strange netstat entries below:
datametrics
sa-msg-port
radius
radacct
squid
afbackup
All of the entries I have listed above had a Time Wait entry next to them.
So my question is, is has my router been compromised? What are those entries from netstat and what is that Windows 10 network adapter doing on my PC?
If my router has been compromised what should I do?
Thanks for your time,
David
datametrics
sa-msg-port
radius
radacct
squid
afbackup
David
