Hi, I am now using an unmanaged (and borrowed) 3com 5-port switch for my home lab of sorts and am considering getting a new switch considering my use case.
My home lab now consists of a Canon AIO printer, my main laptop/desktop replacement, an OpenMediaVault rig using an Intel dual NIC PCIe card, an ESXi host containing at least a few VMs (e.g. a Windows 7 VM) using an Intel single NIC PCIe card and another onboard Atheros NIC, and possibly another computer (not decided if ESXi or just Windows 7) with an onboard NIC. All are connected via Ethernet cables to the switch, and then the switch is connected to an Asus AC66U with another Ethernet cable.
I am trying to do some NIC bonding for the OpenMediaVault rig and the ESXi host, but I am not seeing any speed changes at all, which made me suspect that the switch needs to support this too, hence I am looking for a new switch. So here's what I need help in:
1. What exact features do I need to look out for? Is LADP or 802.11ad the right keyword to look into?
2. What else should I look out for?
3. Will 8 ports be enough for my use case or should I aim for 16 ports?
4. Is the TP-Link SG2008 ok, or should I go for a HP or even Cisco?
Thanks!
Thanks!
