Is it a mesh setup? Also how is the range of a single eap245 vs an asus router?Yes, TL-SG108PE switch, 2 EAP245V3 APs, OC200 controller. PoE powered, running great. Much better than AiMesh.
Is it a mesh setup?
I don't know what do you mean by "mesh setup". Most consumer products are mesh only in the name. Pure marketing. There is no mesh with 2 APs. There is no true mesh with AiMesh. Omada is centrally managed system of wired APs. Similar to UniFi.
Bro, can you confirm if TL-SG108PE can adopt with OMADA OC200 controller ? thanks in advanceTL-SG108PE
Welcome To SNBForums
