My Location E for the powerline tests has many wall-wart adapters plugged in. I unplug them ALL while I test, even adapters in the next room.
I'm not sure I understand your reply.
I'm guessing the AC power converters can add noise back onto the house wiring. If this is the case, good thing we only have about a hundred of these all over the house
That said, I've found an outlet strip, even cheapies with no surge protection or filtering, can provide some high-frequency noise filtering. So you have that going for you in your setup.
So if this is the case, then plugging the power adapters into power strips with some line filtering might help keep the noise down on the house wiring?
If this isn't the case, please enlighten me.
