Traffic Analyzer requirements?
fr33z0n3r
Can't seem to find much info about what you need to have setup for this new feature to work. I have JFFS enabled, and I just formatted the disk with a reboot. (but it was set by default when I reset the router)
I still have no data showing in here.
Does this feature require any other features to be enabled?
running 378.51 here.
UPDATE: Oh snap, it started working! OK. Ignore my post.
For the record, this feature does not work until you format the JFFS and reboot once. I enabled the feature yesterday and no charts populated, until a JFFS format and reboot was completed.
Info. is updated every hour so when you start it you have to wait this hour until any data shows up.
lol, posted at the same time. Yeah, I guess the JFFS format was required, with the reboot. Which surprises me, since it was setup fresh. Maybe in the future ASUS or merlin can make it work if JFFS is enabled anyway by default.
