again, for those with issues while on .41;
hw accel on?
if it's off, QoS enabled?
IPv6 enabled?
hw accel on?
whatever the default is I believe it's on.
OFF
IPv6 enabled?
Disabled
hw accel on?
IPv6 enabled?
what ISPs are you all using?
Is there a way I could help by running a debug load of .41 (RT-N66U) with additional info? The output of 'cat /proc/net/dev' looks ok to me, so the issue should be in the module that processes that data and stores it for 24h ...
This is what my chart looks like:
I have VDSL2 from bell and experiencing same thing. However I am wondering if any of you have set "Idle Disconnect Time in seconds: Disconnect after time of inactivity (in seconds)" to zero. If so it may be possible router is sending dummy packet to modem or ISP to keep connection alive and that is increasing value of data send.
Similar to hello packets in routing protocols.
Merlin is there any chance you could assist fantom in trouble shooting these.
These stats are very useful, as in Canada the main carriers charge quite a bit for over usage, and although they do provide methods of checking usage, it is much more convenient to use the stats from the router.
Thanks in advance.
I already tried, as discussed in the other thread devoted to this issue, and I can't find it. Asus, or another developer who can reproduce the issue will have to.
Keep in mind that this is code that wasn't written by me, and contains next to zero comments explaining how it works. It's not as simple as debugging code which you wrote yourself.
We use essential cookies to make this site work, and optional cookies to enhance your experience.
