Traffic Monitor broken? [EDIT: Resolved]
logic88
Sorry but I guess I made a newbie mistake.
I went ahead and enabled QoS and now the Traffic Monitor seems to work correctly.
Thanks!
-----Original Message-----
Just upgraded to an RT-AC68U and flashed 376.48_1 on it.
Aside from not being able to set TX power, I'm generally happy with the speed and stability so far.
But I am confused by the Traffic Monitor feature though.
Right now, I'm downloading a large ISO so it's all download and very little upload. But when I go to the Traffic Monitor page and the "Primary WAN" tab, it's showing almost symmetrical download/upload speeds (~11Mbit) for the real time view. If I go to the daily view, it also shows symmetrical speeds.
If I go into the "Wired" tab, it doesn't show hardly anything for the download (less than .1 Mbit) and the upload is showing as 1Mbit, which doesn't seem correct either.
Is the Traffic Monitor broken or am I confused?
Thanks for any help!
