SNBForums
This is a sample guest message. Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
transmission-daemon 100% cpu load
Swap file should help with transmission. First I followed the update and upgrade process in this post for entware and the problem disappeared re: cpu usage...worth a try..just type the command he wrote in bold letters into a telnet session exactly as it's written and let it do all it's updates including an update for transmission. When it's completed issue the reboot command in telnet and see if the problem goes away...good luck
http://forums.smallnetbuilder.com/showpost.php?p=114980&postcount=5
