Transmission "dead"
sunnyogosanyi
Hello everyone,
I've used the transmission on my RT-AC68U router before, but now I updated the firmware and I've freshly installed again the entware and the transmission.
The starting of the transmission is done without any error message, but if I check the status, I've got the following:
Checking transmission-daemon... dead.
I've tried with an older firmware which was used before and the problem is the same. Do you have any ideas what happened?
Thank you in advance!
Use the Better Search function at the top of the page to find the recent posts discussing this problem.
Colin is correct as you really should be using the search function before posting something a few people have already discussed…but since you're new I'll give you a pass. See below the links to what you need to review as this is a new known issue with the latest transmission and entware.
Follow from this point on for the temp fix
