ct 29 15:13:31 rc_service: ntp 885:notify_rc restart_upnp
Oct 29 15:13:31 miniupnpd[893]: shutting down MiniUPnPd
Oct 29 15:13:32 miniupnpd[930]: version 1.9 started
Oct 29 15:13:32 miniupnpd[930]: HTTP listening on port 43934
Oct 29 15:13:32 miniupnpd[930]: Listening for NAT-PMP/PCP traffic on port 5351
Oct 29 15:13:32 rc_service: ntp 885:notify_rc restart_diskmon
Oct 29 15:13:32 disk_monitor: Finish
Oct 29 15:13:33 ddns update: connected to nwsrv-ns1.asus.com (103.10.4.108) on port 80.
Oct 29 15:13:34 disk monitor: be idle
Oct 29 15:13:34 ddns update: Asus update entry:: return: HTTP/1.1 200 OK^M Date: Sun, 29 Oct 2017 12:13:34 GMT^M Server: Apache^M X-Powered-By: PHP/5.6.30^M Content-Length: 0^M Connection: close^M Content-Type: text/html; charset=UTF-8^M ^M
Oct 29 15:13:34 ddns update: retval= 0, ddns_return_code (,200)
Oct 29 15:13:34 ddns update: asusddns_update: 0
Oct 29 15:13:34 ddns: ddns update ok
Oct 29 15:13:36 kernel: * Make sure sizeof(struct sw_struct)=160 is consistent
Oct 29 15:13:36 kernel: sizeof forward param = 160
Oct 29 15:13:40 rc_service: udhcpc 570:notify_rc start_firewall
Oct 29 15:13:40 dhcp client: bound 46.216.54.20 via 46.216.0.1 during 600 seconds.
Oct 29 15:13:41 miniupnpd[930]: shutting down MiniUPnPd
Oct 29 15:13:41 start_nat_rules: apply the nat_rules(/tmp/nat_rules_eth0_eth0)!
Oct 29 15:13:42 miniupnpd[1062]: version 1.9 started
Oct 29 15:13:42 miniupnpd[1062]: HTTP listening on port 40129
Oct 29 15:13:42 miniupnpd[1062]: Listening for NAT-PMP/PCP traffic on port 5351
Oct 29 15:13:52 qtn: bootcfg.tgz exists
Oct 29 15:13:58 crond[474]: time disparity of 1181533 minutes detected
Oct 29 15:14:27 asusware: re-mount partition /dev/sda1...
Oct 29 15:14:27 disk monitor: re-mount partition
Oct 29 15:14:27 usb: USB /dev/sda1(ntfs) failed to mount At the first try!
Oct 29 15:14:27 usb: USB ntfs fs at /dev/sda1 mounted on /tmp/mnt/Seagate_Backup_Plus_Drive.
Oct 29 15:14:27 asusware: done.
Oct 29 15:14:27 disk monitor: done
Oct 29 15:14:29 rc_service: hotplug 850:notify_rc restart_nasapps
Oct 29 15:14:29 iTunes: daemon is stoped
Oct 29 15:14:29 FTP Server: daemon is stoped
Oct 29 15:14:30 Samba Server: smb daemon is stoped
Oct 29 15:14:30 kernel: gro disabled
Oct 29 15:14:30 Timemachine: daemon is stoped
Oct 29 15:14:30 miniupnpd[1062]: shutting down MiniUPnPd
Oct 29 15:14:30 kernel: gro enabled with interval 2
Oct 29 15:14:31 Samba Server: daemon is started
Oct 29 15:14:31 miniupnpd[1318]: version 1.9 started
Oct 29 15:14:31 miniupnpd[1318]: HTTP listening on port 45748
Oct 29 15:14:31 miniupnpd[1318]: Listening for NAT-PMP/PCP traffic on port 5351
Oct 29 15:19:48 dropbear[2049]: Password auth succeeded for 'admin' from 192.168.1.120:59418
