Transmission ipv6 problem
netspy2
Hello!
I have Asus RT-AC68U router with firmware 376.48_1. I setup transmission with this manual. When i run start script then launched four process of transmission-daemon. And in log present string "Couldn't bind port xxxxx on ::: Address already in use (Is another copy of Transmission already running?)". IPv4 fine.
On Asus RT-N66U with entware all right, launched one process.
Also with the daemon aiccu, four same process. But it working.
Any ideas?
Sorry if double. And sorry for my english.
#ps
9301 admin 2880 S /opt/sbin/aiccu start /opt/etc/aiccu.conf
9306 admin 2880 S /opt/sbin/aiccu start /opt/etc/aiccu.conf
9307 admin 2880 S /opt/sbin/aiccu start /opt/etc/aiccu.conf
9318 admin 2880 S /opt/sbin/aiccu start /opt/etc/aiccu.conf
9791 admin 13976 S /opt/bin/transmission-daemon -a *.*.*.* -g /opt/etc/transmission-daemon -e /opt/var/log/transmission-daemon
9793 admin 13976 S /opt/bin/transmission-daemon -a *.*.*.* -g /opt/etc/transmission-daemon -e /opt/var/log/transmission-daemon
9794 admin 13976 S /opt/bin/transmission-daemon -a *.*.*.* -g /opt/etc/transmission-daemon -e /opt/var/log/transmission-daemon
9798 admin 13976 S /opt/bin/transmission-daemon -a *.*.*.* -g /opt/etc/transmission-daemon -e /opt/var/log/transmission-daemon
