S
said006
Guest
[deleted]
you do not need ext3 to save torrents. You can use your ntfs drive to save torrents. You need ext3 partition to install transmission and entware. Use a ext3USB stick to install transmission and change settings.json settings of download directory and other directories to your ntfs drive.
As you said I've installed entware and Transmission on my usb stick on USB2 port, and set to download on my ntfs hard drive set on USB3 port.It is possible to change hard disk on USB3 port with Transmission folders ready?I've tried but torrents don't save and gives me error.
Welcome To SNBForums
