Trouble with network services filter...
Source and destination are relative terms in Wireshark depending on the direction the traffic is flowing. This is not the case with the Network Services Filter where the source is the LAN and the destination is the internet.
PS I'm presuming you are not using a VPN.
sorry for the delayed replies. Sometimes rebooting my router sends my cable modem into a tizzy.
Well, this time it seems to have worked. Fired up the game and couldn't connect to any servers. Turned off the"Enable Network Services Filter" and then I could connect again.. Turned the filter back on and unfortunately I stayed connected to the game I was in, and I quit that match and was able to connect to a new one. Closed the game and steam app, and could not connect to a new match.
So, I am partially solved. I want to be able to easily toggle between allowing and not allowing. The radio button to enable / disable the network services filter is pretty decent. Would be cool if I could use scp to just push up the iptables rules I want with just a simple command line. Guessing this is possible. Is it possible to setup ssh authorized hosts for your asus router to allow you to scp / ssh without a password so I could just execute a script to push the right file or execute the right command to turn on / off the network services filter?
Here is my config and iptables-save now.
I have blocked the ports in both directions (I hope) see below:
Intere
Here is the output from iptables-save:
# Generated by iptables-save v1.3.8 on Mon Sep 4 09:52:47 2017
*nat
:PREROUTING ACCEPT [972:111422]
:POSTROUTING ACCEPT [468:36571]
:OUTPUT ACCEPT [464:36411]
:DNSFILTER - [0:0]
:LOCALSRV - [0:0]
:PCREDIRECT - [0:0]
:PUPNP - [0:0]
:VSERVER - [0:0]
:VUPNP - [0:0]
-A PREROUTING -d 97.93.29.121 -j VSERVER
-A POSTROUTING -o eth0 -j PUPNP
-A POSTROUTING -s ! 97.93.29.121 -o eth0 -j MASQUERADE
-A POSTROUTING -m mark --mark 0x8000/0x8000 -j MASQUERADE
-A VSERVER -p tcp -m tcp --dport 50000 -j DNAT --to-destination 192.168.1.1:50001
-A VSERVER -j VUPNP
-A VSERVER -j LOCALSRV
-A VSERVER -j DNAT --to-destination 192.168.1.105
COMMIT
# Completed on Mon Sep 4 09:52:47 2017
*mangle
:PREROUTING ACCEPT [12769:5115012]
:INPUT ACCEPT [6702:1023872]
:FORWARD ACCEPT [8547:4534953]
:OUTPUT ACCEPT [4225:2808615]
:POSTROUTING ACCEPT [15289:8013704]
:QOSO0 - [0:0]
-A PREROUTING -d 192.168.100.20 -i ! eth0 -j MARK --set-mark 0x8000/0x8000
-A PREROUTING -d 97.93.29.121 -i ! eth0 -j MARK --set-mark 0x8000/0x8000
-A PREROUTING -i eth0 -j CONNMARK --restore-mark --mask 0x7
-A FORWARD -o eth0 -j QOSO0
-A OUTPUT -o eth0 -j QOSO0
-A POSTROUTING -o br0 -j QOSO0
-A QOSO0 -j CONNMARK --restore-mark --mask 0x7
-A QOSO0 -m connmark ! --mark 0x0/0xff00 -j RETURN
-A QOSO0 -p tcp -m tcp --dport 80 -m connbytes --connbytes 0:524287 --connbytes-mode bytes --connbytes-dir both -j CONNMARK --set-return 0x2/0x7
-A QOSO0 -p tcp -m tcp --dport 443 -m connbytes --connbytes 0:524287 --connbytes-mode bytes --connbytes-dir both -j CONNMARK --set-return 0x2/0x7
-A QOSO0 -p tcp -m tcp --dport 80 -m connbytes --connbytes 524288:4294967295 --connbytes-mode bytes --connbytes-dir both -j CONNMARK --set-return 0x3
-A QOSO0 -p tcp -m tcp --dport 443 -m connbytes --connbytes 524288:4294967295 --connbytes-mode bytes --connbytes-dir both -j CONNMARK --set-return 0x
-A QOSO0 -p tcp -m tcp --dport 27014:27050 -m mac --mac-source 60:F8:1D:C1:F9:00 -j CONNMARK --set-return 0x1/0x7
-A QOSO0 -p udp -m multiport --dports 1200,3478,4379:4380,27000:27030 -m mac --mac-source 60:F8:1D:C1:F9:00 -j CONNMARK --set-return 0x1/0x7
-A QOSO0 -p tcp -m tcp --dport 27014:27050 -m mac --mac-source 80:E6:50:0B:86:EA -j CONNMARK --set-return 0x1/0x7
-A QOSO0 -p udp -m multiport --dports 1200,3478,4379:4380,27000:27030 -m mac --mac-source 80:E6:50:0B:86:EA -j CONNMARK --set-return 0x1/0x7
-A QOSO0 -p tcp -m tcp --dport 27014:27050 -m mac --mac-source 60:F8:1D:BD:6E:70 -j CONNMARK --set-return 0x1/0x7
-A QOSO0 -p udp -m multiport --dports 1200,3478,4379:4380,27000:27030 -m mac --mac-source 60:F8:1D:BD:6E:70 -j CONNMARK --set-return 0x1/0x7
-A QOSO0 -d 224.0.0.0/240.0.0.0 -j CONNMARK --set-return 0x6/0x7
-A QOSO0 -d 192.168.1.0/255.255.255.0 -j CONNMARK --set-return 0x6/0x7
-A QOSO0 -j CONNMARK --set-return 0x4/0x7
COMMIT
*filter
:INPUT ACCEPT [0:0]
:FORWARD DROP [0:0]
:OUTPUT ACCEPT [4542:2913292]
:ACCESS_RESTRICTION - [0:0]
:FUPNP - [0:0]
:INPUT_ICMP - [0:0]
:NSFW - [0:0]
:PControls - [0:0]
:PTCSRVLAN - [0:0]
:PTCSRVWAN - [0:0]
:SECURITY - [0:0]
:logaccept - [0:0]
:logdrop - [0:0]
-A INPUT -i eth0 -p icmp -m icmp --icmp-type 8 -j DROP
-A INPUT -m state --state RELATED,ESTABLISHED -j ACCEPT
-A INPUT -m state --state INVALID -j DROP
-A INPUT -i ! br0 -j PTCSRVWAN
-A INPUT -i br0 -j PTCSRVLAN
-A INPUT -i br0 -m state --state NEW -j ACCEPT
-A INPUT -i lo -m state --state NEW -j ACCEPT
-A INPUT -p udp -m udp --sport 67 --dport 68 -j ACCEPT
-A INPUT -d 192.168.1.1 -p tcp -m conntrack --ctstate DNAT -m tcp --dport 50001 -j ACCEPT
-A INPUT -p icmp -j INPUT_ICMP
-A INPUT -j DROP
-A FORWARD -m state --state RELATED,ESTABLISHED -j ACCEPT
-A FORWARD -i ! br0 -o eth0 -j DROP
-A FORWARD -i eth0 -m state --state INVALID -j DROP
-A FORWARD -i br0 -o br0 -j ACCEPT
-A FORWARD -i eth0 -j SECURITY
-A FORWARD -j NSFW
-A FORWARD -m conntrack --ctstate DNAT -j ACCEPT
-A FORWARD -i br0 -j ACCEPT
-A INPUT_ICMP -p icmp -m icmp --icmp-type 8 -j RETURN
-A INPUT_ICMP -p icmp -m icmp --icmp-type 13 -j RETURN
-A INPUT_ICMP -p icmp -j ACCEPT
-A NSFW -i br0 -o eth0 -p udp -m udp --sport 4379:4380 -j DROP
-A NSFW -i br0 -o eth0 -p tcp -m tcp --sport 27000:27100 -j DROP
-A NSFW -i br0 -o eth0 -p udp -m udp --sport 27000:27100 -j DROP
-A NSFW -i br0 -o eth0 -p udp -m udp --dport 4379:4380 -j DROP
-A NSFW -i br0 -o eth0 -p udp -m udp --dport 27000:27100 -j DROP
-A NSFW -i br0 -o eth0 -p tcp -m tcp --dport 27000:27100 -j DROP
-A NSFW -i br0 -o eth0 -j RETURN
-A PControls -j ACCEPT
-A SECURITY -d 192.168.1.105 -j RETURN
-A SECURITY -p tcp -m tcp --tcp-flags FIN,SYN,RST,ACK SYN -m limit --limit 1/sec -j RETURN
-A SECURITY -p tcp -m tcp --tcp-flags FIN,SYN,RST,ACK SYN -j DROP
-A SECURITY -p tcp -m tcp --tcp-flags FIN,SYN,RST,ACK RST -m limit --limit 1/sec -j RETURN
-A SECURITY -p tcp -m tcp --tcp-flags FIN,SYN,RST,ACK RST -j DROP
-A SECURITY -p icmp -m icmp --icmp-type 8 -m limit --limit 1/sec -j RETURN
-A SECURITY -p icmp -m icmp --icmp-type 8 -j DROP
-A SECURITY -j RETURN
-A logaccept -m state --state NEW -j LOG --log-prefix "ACCEPT " --log-tcp-sequence --log-tcp-options --log-ip-options
-A logaccept -j ACCEPT
-A logdrop -m state --state NEW -j LOG --log-prefix "DROP " --log-tcp-sequence --log-tcp-options --log-ip-options
-A logdrop -j DROP
COMMIT
Intere
*nat
:pREROUTING ACCEPT [972:111422]
:pOSTROUTING ACCEPT [468:36571]
:DNSFILTER - [0:0]
:LOCALSRV - [0:0]
:pCREDIRECT - [0:0]
:pUPNP - [0:0]
:VSERVER - [0:0]
:VUPNP - [0:0]
-A VSERVER -j VUPNP
COMMIT
*mangle
:pREROUTING ACCEPT [12769:5115012]
:pOSTROUTING ACCEPT [15289:8013704]
:QOSO0 - [0:0]
COMMIT
*filter
:INPUT ACCEPT [0:0]
:FORWARD DROP [0:0]
:FUPNP - [0:0]
:INPUT_ICMP - [0:0]
:NSFW - [0:0]
:pControls - [0:0]
:pTCSRVLAN - [0:0]
:pTCSRVWAN - [0:0]
:SECURITY - [0:0]
:logaccept - [0:0]
:logdrop - [0:0]
-A INPUT -j DROP
-A FORWARD -j NSFW
-A logdrop -j DROP
COMMIT
Please post in a CODE block
OK, I think I see the problem. Here are the relevant iptables rules:
 -A FORWARD -j NSFW
The blocking rules (NSFW) are called towards the end of the FORWARD chain, therefore once a connection has been established it will then be accepted by the first rule in the chain. So it never subsequently gets to the blocking rules. This explains the behaviour you are seeing. Turning the NSF off and on doesn't break any already established connections.
So your idea of a script might be the best solution because you could insert your rules at the beginning of the FORWARD chain (before the RELATED,ESTABLISHED rule), like this:
-I FORWARD -i br0 -o eth0 -p udp -m udp --dport 4379:4380 -j DROP
-I FORWARD -i br0 -o eth0 -p udp -m udp --dport 27000:27100 -j DROP
-I FORWARD -i br0 -o eth0 -p tcp -m tcp --dport 27000:27100 -j DROP
That should be do-able. You can set up passwordless SSH access using certificates.
Actually there's a more sneaky way of doing it ;) that would still allow you to administer the ports through the GUI, but you could enable/disable them through a script.
This is the general principle. Setup and enable the NSF as normal, then
Remove the existing call the NSFW:
iptables -D FORWARD -j NSFW
Then add the call back in again at the front of the chain:
iptables -I FORWARD -j NSFW
To disable the NSF just delete the rule again.
Of course every single packet of data moving between the LAN and WAN (and vice versa) will now be checked by that rule, so it's not the most efficient solution but I can't see another way of blocking an already established connection.
Still digesting this advice... Not sure how to do the deletion and addition remotely. Maybe using plink from windows or piping input to bash as described here: https://stackoverflow.com/questions/305035/how-to-use-ssh-to-run-a-shell-script-on-a-remote-machine
Does the router run bash? Just tried to run it and it says bash not found.... Hmmm...
overall I am pretty disappointed with the way the network services filter works. Tried blocking other sites by keyword. Works some of the time and not others....
No, the built in shell is ash (but it's also called /bin/sh and is part of busybox). Remember, this isn't a Linux distribution it's a small footprint embedded consumer device that Merlin has opened up to allow for user modification.
If you are referring to the URL/keyword filter then that will increasingly be the case for any router as warned about in the GUI:
1. Compressed webpages that use HTTP compression technology cannot be filtered.
2. Https webpages cannot be filtered.
@snevah admin Following up on the changes to the iptables rules we discussed;
To make things simpler and working how you want you can create a firewall user script as follows. This will automatically move the NSFW call to the desired location every time you enable the Network Services Filter in the GUI or the firewall is restarted for any other reason.
/jffs/scripts/firewall-start
#!/bin/sh
if [ "$(nvram get fw_lw_enable_x)" = "1" ]
then
    logger -t $(basename $0) "Moving NSFW"
fi
You should then see the following entry in the syslog:
Sep  5 15:05:23 firewall-start: Moving NSFW
Be warned that switching from a blacklist to a whitelist might have some unexpected consequences (I've not seen the iptables rules so I don't know how it's been implemented).
This is what worked for me with an Asus RT-AC68U: Enter the ports only in the box to the far right (to the right of destination IP). Leave everything else blank. I tested with: portquiz.net
