Jack Yaz
Part of the Furniture
For some reason, ntp will not reliably sync for me on reboot for me.
I can see the below process running:
but time never syncs. If I manually re-run the command, time is set immediately. Is there any way to get logging out of ntp so I can check why it is not syncing?
RT-AC86U 384.17
/usr/sbin/ntp -t -S /sbin/ntpd_synced -p pool.ntp.org -p time.nist.gov
RT-AC86U 384.17
