Trying to determine which networking components to purchase for my uses
sneak
I'm currently using a Hitron CODA56 modem with 1000/100 internet and an ASUS RT-AX58U. I'm told by my ISP in the next 5-7 years they plan to have everyone over on Fiber.
I have a TERRAMASTER F4-424 PRO, which has 2x 2.5G ethernet ports. My motherboard is an ASRock X570 Taichi with a 1G ethernet port.
I would like to take advantage of the NAS's connectivity to the fullest extent (in terms of transferring files from my hard drive in my PC to the NAS array). The drives I'm using are two HGST HC320 8 TB in TRAID, with plans to add more in the future. I may switch to RAID10 and UNRAID or TRUENAS if needed, later on. I believe these drives in TRAID or RAID1 can already achieve 280 MB/s transfer but I'm currently limited to about 115 MB/s with my 1G internet connectivity from my computer.
I'm interested in switching to WiFi 6E and want a PCI NIC and a router or router and switch combination (less parts/expenses the better, unless there's a good reason to have more) that allows me to take advantage of the NAS's connectivity. I believe I can't aggregate those NAS ports, and have read that LAG can be disappointing and complex anyway.. but if possible I would of course be interested in running 5 Gbps to and from the NAS.
So I'm looking around at options and I'm not 100% sure about which router to buy and if I can get away with 1 2.5 Gbps port on the router and no switch or if I should buy a switch.. or just get a router with 2 2.5 Gbps ports (like the 88U Pro). I also am unsure on which network card to get. I care about reliability and latency. I don't want a buggy network card, and with my experience with servers it seems like intel NICs are usually preferable. I've had issues with Marvell SATA controllers at home before, too.
Overall I've been looking into the ASUS RT-AX88U PRO and ASUS RT-AXE7800. I would prefer 6E and the former doesn't provide that. I don't really want to buy one of those $500 routers, either. I'm having a difficult time finding a good option for a NIC but the TP-Link TX201 seems to be the best option I can find that seems well-received in various places online. It's only 2.5G but it would get me what I want out of the NAS (assuming I can't get 5G from this NAS).
So are there any suggestions on a NIC and router (and possibly a switch, if this is useful under the circumstances of the recommendations)?
I would avoid Asus AXE models. RT-AXE7800 is mid-range hardware similar to RT-AX58U with one extra radio. GT-AXE11000 is an old model router 2 hardware generations behind. GT-AXE16000 and ZenWiFi ET12 obviously have firmware issues upstream and stuck on 3004 firmware base. If you need guaranteed Asuswrt-Merlin support firmware going forward - you have to pick BE-class model. If stock Asuswrt is good enough - RT-AX88U Pro runs on stock 3006 firmware, has 2x 2.5GbE ports and on reasonable price.
Thanks. One reason I specifically bought my current modem was merlin support, but I've never even put it on there. I had just moved and was overwhelmed and then never decided like it felt necessary. I do like having the option vs not having it, though.
I was looking into the ASUS RT-BE92U prior to finding the AXE7800, actually. I forgot why I switched off of it, but I know one thing is that I don't have anything that supports WiFi 7 or MLO.
I looked at it again, and it has 4x 2.5G ports and a 10G WAN. Very nice. As long as that 10G steps down to 1G of my modem I can save those 4 other ports and, unless I'm missing something, I could just use that router and a 2.5G NIC to get at least 2.5G to and from the NAS. I also like that you can use the USB port on the router for tethering, because I would assume that it's as simple as the device having tethering turned on and a connection to the router to restore internet. For the rare times my internet goes out I'd rather it be this simple and quick instead of dealing with the poor Windows 10 UI re-design and networking configuration hassles to get back online.
Do you have suggestions for a NIC?
I would look at RT-BE88U or RT-BE86U for more 2.5GbE ports. They both have Asuswrt-Merlin support on 3006 base as well. About 2.5GbE NIC for your PC - whatever is available at reasonable price. They all work with Windows one way or another. About Dual WAN service backup with Asus router - you may be disappointed. It's unreliable and YMMV situation.
Well, good thing the tethering is lower than a tertiary concern for me. The RT-BE86U has 4 2.5GbE ports and 1 10GbE just like the RT-BE92U. The RT-BE88U has 10G SFP+, 10GbE, 4x 2.5GbE, and 4x 1GbE. Other than the high amount of 2.5GbE and Merlin support, were there other reasons to mention these? Or just more options to research?
There is currently only 4x BE-class models supported by RMerlin and 1x model by GNUton. No much of a choice for 3006 base firmware. The rest AX-class models stuck on maintenance mode 3004 base with available stock 3006 Asuswrt for Pro models and a few GT models. All in somewhat beta stage still, expect bugs and fixes over time.
If you ask about my eventual hardware choice including Wi-Fi 6E - it will be Ubiquiti UCG-Max Gateway and U6 Enterprise AP. If single RT-AX58U was enough to cover your place - one AP is perhaps all you need. Comes more expensive than consumer All-In-One router, but the software works out of the box, future expandability is much better and is user-friendly enough. I'm done with beta testing consumer products. If AIO unit - Synology RT6600ax. Software quality and compatibility are above average.
If you ask about my eventual hardware choice including Wi-Fi 6E - it will be Ubiquiti UCG-Max Gateway and U6 Enterprise AP. If single RT-AX58U was enough to cover your place - one AP is perhaps all you need. Comes more expensive than consumer All-In-One router, but the software works out of the box, future expandability is much better and is user-friendly enough. I'm done with beta testing consumer products. If AIO unit - Sinology RT6600ax. Software quality and compatibility are above average.
I didn't know Synology made routers lol. I lean a little away from the company due to what seems to me to be an "Apple-like" nature of trying to lock people down into their system and force them to use proprietary things. I don't really like that. I do always have a positive feeling about Ubiquiti products, but have never used any. I'm sure I'd love the coverage and performance of the products but I can't justify spending all that right now. I do have at least 1 dead zone in my kitchen when I bring my phone near the cutting board (sometimes) but this may be resolved by switching routers. I don't know. Also, switching to another ASUS router I guess would allow me to use my current one as a mesh, and I could just place it in the kitchen :D.
If you avoid Apple-like products - Ubiquiti is not for you. It's the Apple in networking. Started by an Apple engineer and similar down to the way boxes open. Otherwise works as advertised, wide range of products in their ecosystem and high quality. About Synology - I have one RT2600ac still in use and the software is really good. The new RT6600ax must be running similar SRM.
Oh, okay. I hadn't researched the Ubiquiti products to purchase -- just saw them in passing. I researched Synology for a purchase.
I think I'm content enough with the options from ASUS and I'll research those 3 models when I have time.
Whatever you are comfortable with as software and fits your budget as hardware. Don't overpay for unused features.
I've narrowed things down in terms of the differences between the three:
$300 RT-BE86U (vertical standing. 1 GB less ram than 88 and slower theoretical 2.4 speeds. WAN 10G, WAN 2.5G w/ total 4 2.5G)
$347 RT-BE88U (traditional standing. 1 GB more ram than 86 and faster 2.4 speeds than 86U and 92U. sfp+, WAN 10G, WAN 2.5G w/ total 4 2.5G and 4 1G)
$240 RT-BE92U (vertical standing. same ram and theoretical 2.4 speeds as 86U. WAN 10G w/ total 4 2.5G)
Aside from these basic details, I couldn't find as much (useful) information about the BE92U as the other two. One question is how much of a difference the 2 GB ram would make over 1 GB, and in which circumstances would this even matter?
Assuming the vertical and traditional ones were identical otherwise, I would prefer vertical because it saves desk space and my CODA56 is vertical as well.
I'm not sure the usefulness of SFP+ as I don't know much about fiber and brief research about this didn't really help. Plus, by the time I get fiber I'm not sure I'd want the same router.. so to me at the moment the SFP+ port is unimportant.
I only need to connect my work computer, personal computer, and my NAS via ethernet so I don't need 4+ ports and if I needed more than 4 I could buy a switch but it's unlikely I'll need more than these by the time this router is replaced... so I don't consider the extra ports to be useful.
So assuming the RAM being 1 GB rather than 2 GB isn't an issue, I would think the RT-BE92U would best suit my needs. Let me know if I'm missing something.
With your additional preferences and limited choice I would pick RT-BE86U instead.
- Asuswrt-Merlin support vs stock Asuswrt only
- faster/newer 2.6GHz CPU vs 2.0GHz CPU
- better 4-stream 5GHz radio vs 2-stream 5/6GHz radios
- 2x USB ports vs 1x USB port
- looks better IMO
- overall higher class dual-band model vs mid-range tri-band
Honestly, if your existing RT-AX58U is doing the job well this upgrade won't improve much your user experience. You get 2.5GbE ports and faster access to NAS eventually, but whatever is on Wi-Fi won't notice big difference. Don't count phones/tablets. ISP upgrade in years... when the time comes better and perhaps cheaper models will be available. There is no futureproofing with home routers. By the time you really have the need for faster ISP and Wi-Fi this new router will be on the EoL list.
- looks better IMO
- I'm confused. You mentioned GNUTON earlier and I looked it up and it appears to indicate that the 92U is supported.
- The information I saw for CPU indicated they share a 2.6 Ghz quad-core. DongKnows may have gotten that wrong. I do see on the ASUS website they indicate the 86U has a different CPU. I guess it could also be something to do with regional versions or revisions of the units.
- DongKnows website also indicated 2x2 5Ghz for both units, where the ASUS site indicates what you stated. 4x4 would be an upgrade over my current RT-AX58U for sure.
- I'm not sure what I'd do with all these USB ports, but sure. Let's count it :P
- I'm indifferent between the two.
That's what I was thinking. No point caring about future stuff because I'd end up replacing this router. Yes, the main reason is the desire for faster local transfer speeds :).
- look again which exactly BE-class model is supported by GNUton's Asuswrt-Merlin fork
- if you are going to verify information provided on SNB Forums with Dong - I'm out, wasting my time.
You don't need a router for this, but a 2.5GbE switch. It's much cheaper. Good luck.
I see on the supported devices list it is the AX92 that is supported. Nevermind. Speaking of that, I just flashed Merlin on my RT-AX58U and already just from a visuals standpoint even at the login screen it's much better. Instead of that bloated thing that doesn't account for modern resolutions it's much better.. as is the main screen. I can't wait to explore the actual features :).
I'm not verifying information from SNB with Dong. What I said was that the reason I thought they were the same was because of what I saw on Dong's site prior to you mentioning this information.
Yes, this is why in my original post I mentioned wanting to use "less components" and "get away with" using the router, rather.
To put it simply, my understanding is I can just buy the faster NIC for my PC and the switch that supports 2.5 Gbps and already solve my NAS data transfer bottleneck.
Also, if you guys have some kind of dislike of Dong here, I'm not aware of that. I don't know anything about the SNB culture. I'm pretty new around here.
Questionable reviews and test methods. Got popular because few sites of this type still exist. Very far from what SmallNetBuilder was doing with professional equipment and analysis from a person who worked in the field for years. If you need correct information about Asus routers in particular - SNB Forums is the best source. I can't speak about other forum members, but I find quite often incorrect information on Dong's website.
Lawrence Systems with their YouTube channel:
Crosstalk Solutions have good networking content as well:
Network Chuck for funny but good information videos:
This way of presenting information killed text and pictures websites.
