TS-231 + Asus RT-88CU = Problems
Meto
Not sure where to begin, but the last couple of times I have installed the firmware for my TS-231, it will show up for 30 minutes to 1 hour and then vanish from the network. It is running, but I cannot access it via web, drive shares, SSH or by any other means. If I power it off and back on, when it reloads, I can then use it once again for 30 minutes to an hour and then once again it vanishes.
Both the TS-231 and the Asus router have the latest firmware available and I even did a factory reset on my Asus router as I thought that was the problem. I really do not want to downgrade the QNAP if at all possible. I am using link aggregation if that makes any difference. I have tried everything I can think of at this point to resolve the issue.
If anyone else has had this issue, please let me know if you were able to address the problem.
Thank You
Can someone tell me if I can safely downgrade my TS-231 from 4.3 to 4.2? I definitely don't want to lose any data, but the NAS doesn't stay connected long enough to get the data off.
