can anyone guess why my new router restarts every few minutes? I upgraded to the newest firmware right after I bought it a few days ago. Since then I tried to restart multiple times, I did factory reset twice, I also uploaded the latest firmware manually again. I always set it up manually from scratch (changing IP address, changing wifi name, changing DHCP address range, setting up a few static IP address assignments, adding one AiMesh node, adding 2.4 and 5Ghz guest networks, disabling NAT Acceleration, enabling AiProtection)
Here's what's in the logs for the restart:
I also started to see Link Paused in the Mikrotik switch where the LAN port of the router is connected to.
I also occasionally see regular sites being blocked by Trend Micro, even router's local address sometimes. And I was getting blocked even after I turned AiProtection off.
I previously had Asus RT-AC68U as the main router which was configured the same and I had no such issues.
May 5 07:05:12 kernel: klogd started: BusyBox v1.25.1 (2023-06-14 11:25:00 CST)
May 5 07:05:12 kernel: Linux version 5.4.182 (root@asus) (gcc version 8.4.0 (OpenWrt GCC 8.4.0 r0-db7dd77)) #1 SMP Wed Jun 14 11:25:56 CST 2023
May 5 07:05:12 kernel: Kernel command line: root_rfs=0x31fc1c rootfstype=squashfs ubi.mtd=UBI_DEV console=ttyS0,115200n1 loglevel=8 earlycon=uart8250,mmio32,0x11002000 root=/dev/mtdblock6
May 5 07:05:12 kernel: _ Reboot message ... _______________________________________________________
May 5 07:05:12 kernel: crash_log: Unable to handle kernel paging request at virtual address ffffffc013000002
May 5 07:05:12 kernel: crash_log: Mem abort info:
May 5 07:05:12 kernel: crash_log: ESR = 0x96000021
May 5 07:05:12 kernel: crash_log: EC = 0x25: DABT (current EL), IL = 32 bits
May 5 07:05:12 kernel: crash_log: SET = 0, FnV = 0
May 5 07:05:12 kernel: crash_log: EA = 0, S1PTW = 0
May 5 07:05:12 kernel: crash_log: Data abort info:
May 5 07:05:12 kernel: crash_log: ISV = 0, ISS = 0x00000021
May 5 07:05:12 kernel: crash_log: CM = 0, WnR = 0
May 5 07:05:12 kernel: crash_log: swapper pgtable: 4k pages, 39-bit VAs, pgdp=0000000048886000
May 5 07:05:12 kernel: crash_log: [ffffffc013000002] pgd=000000005ffff003, pud=000000005ffff003, pmd=0068000018000705
May 5 07:05:12 kernel: crash_log: Internal error: Oops: 96000021 [#1] SMP
May 5 07:05:12 kernel: crash_log: Modules linked in: mtk_warp_proxy(P) mtk_warp mt_wifi(P) mtkhnat conninfra ebtable_filter tdts_udbfw(P) tdts_udb(P) tdts(P) nf_nat_sip nf_conntrack_sip nf_nat_h323 nf_conntrack_h323 nf_nat_rtsp nf_conntrack_rtsp nf_nat_ftp nf_conntrack_ftp ip6table_mangle hfsplus hfs vfat fat ext2 ext4 jbd2 mbcache uas usb_storage sg sd_mod ebt_ip ebtable_broute ebtables ip6table_filter ipheth qmi_wwan cdc_wdm cdc_ncm rndis_host cdc_ether asix cdc_acm usbnet mii ehci_hcd xhci_mtk xhci
May 5 07:05:12 kernel: crash_log: CPU: 1 PID: 7361 Comm: networkmap Tainted: P 5.4.182 #1
May 5 07:05:12 kernel: crash_log: Hardware name: TUF-AX6000 (DT)
May 5 07:05:12 kernel: crash_log: pstate: 60000005 (nZCv daif -PAN -UAO)
May 5 07:05:12 kernel: crash_log: pc : pci_free_rx_buf+0x24c/0x4a10 [mt_wifi]
May 5 07:05:12 kernel: crash_log: lr : pci_free_rx_buf+0x1dc/0x4a10 [mt_wifi]
May 5 07:05:12 kernel: crash_log: sp : ffffff8015863660
May 5 07:05:12 kernel: crash_log: x29: ffffff8015863660 x28: ffffffc01083d850
May 5 07:05:12 kernel: crash_log: x27: 0000000002206d58 x26: 0000000000000002
May 5 07:05:12 kernel: crash_log: x25: ffffffc014936000 x24: 0000000000000000
May 5 07:05:12 kernel: crash_log: x23: 0000000000000004 x22: ffffffc015ae6000
May 5 07:05:12 kernel: crash_log: x21: ffffff8014010a30 x20: ffffff801597f800
May 5 07:05:12 kernel: crash_log: x19: ffffff8014010000 x18: 0000000000020000
May 5 07:05:12 kernel: crash_log: x17: 0000000000000000 x16: 0000000000000000
May 5 07:05:12 kernel: crash_log: x15: 00000000fffffff0 x14: ffffffc010919da0
May 5 07:05:12 kernel: crash_log: x13: 000000000000ecbc x12: ffffffc010980000
May 5 07:05:12 kernel: crash_log: x11: ffffffc010919000 x10: ffffffc0109800c8
May 5 07:05:12 kernel: crash_log: x9 : 0000000000000000 x8 : ffffffc010396af0
May 5 07:05:12 kernel: crash_log: x7 : ffffffc014936000 x6 : 0000000000000002
May 5 07:05:12 kernel: crash_log: x5 : 0000000000000000 x4 : 0000000000000093
May 5 07:05:12 kernel: crash_log: x3 : ffffffc008f2b568 x2 : 0000000000000000
May 5 07:05:12 kernel: crash_log: x1 : 0000000000000002 x0 : ffffffc013000002
May 5 07:05:12 kernel: crash_log: Call trace:
May 5 07:05:12 kernel: crash_log: pci_free_rx_buf+0x24c/0x4a10 [mt_wifi]
May 5 07:05:12 kernel: crash_log: hw_io_read32+0x38/0x48 [mt_wifi]
May 5 07:05:12 kernel: crash_log: chip_chk_exception_type+0x3460/0x8b70 [mt_wifi]
May 5 07:05:12 kernel: crash_log: Show_FwDbgInfo_Proc+0x30/0x40 [mt_wifi]
May 5 07:05:12 kernel: crash_log: AndesSendCmdMsg+0x6f8/0xdb8 [mt_wifi]
May 5 07:05:12 kernel: crash_log: chip_cmd_tx+0x3c/0x48 [mt_wifi]
May 5 07:05:12 kernel: crash_log: MtCmdPhyGetRxRate+0xb0/0x138 [mt_wifi]
May 5 07:05:12 kernel: crash_log: GetPhyRxRate+0x60/0x1d8 [mt_wifi]
May 5 07:05:12 kernel: crash_log: RTMPIoctlGetMacTableStaInfo+0x2d8/0x320 [mt_wifi]
May 5 07:05:12 kernel: crash_log: RTMP_AP_IoctlHandle+0x464/0xa20 [mt_wifi]
May 5 07:05:12 kernel: crash_log: rt28xx_ap_ioctl+0xbc0/0x1578 [mt_wifi]
May 5 07:05:12 kernel: crash_log: rt28xx_ioctl+0x50/0x88 [mt_wifi]
May 5 07:05:12 kernel: crash_log: ap_iw_handler+0x3c/0x310 [mt_wifi]
May 5 07:05:12 kernel: crash_log: ioctl_private_call+0x48/0xa0
May 5 07:05:12 kernel: crash_log: wireless_process_ioctl+0xbc/0x178
May 5 07:05:12 kernel: crash_log: wext_handle_ioctl+0x148/0x1c8
May 5 07:05:12 kernel: crash_log: sock_ioctl+0x24c/0x530
May 5 07:05:12 kernel: crash_log: do_vfs_ioctl+0xa4/0xb38
May 5 07:05:12 kernel: crash_log: ksys_ioctl+0x44/0x90
May 5 07:05:12 kernel: crash_log: __arm64_sys_ioctl+0x1c/0xb8
May 5 07:05:12 kernel: crash_log: el0_svc_common.constprop.2+0x7c/0x110
May 5 07:05:12 kernel: crash_log: el0_svc_handler+0x20/0x80
May 5 07:05:12 kernel: crash_log: el0_svc+0x8/0x180
May 5 07:05:12 kernel: crash_log: Code: d65f03c0 f94066a0 b9404fe1 8b010000 (b9400000)
May 5 07:05:12 kernel: crash_log: ---[ end trace 22c40e4bda464119 ]---
May 5 07:05:12 kernel: crash_log: Kernel panic - not syncing: Fatal exception
May 5 07:05:12 kernel: crash_log: SMP: stopping secondary CPUs
May 5 07:05:12 kernel: crash_log: Kernel Offset: disabled
May 5 07:05:12 kernel: crash_log: CPU features: 0x0002,20002008
May 5 07:05:12 kernel: crash_log: Memory Limit: none
May 5 07:05:12 kernel: crash_log: Rebooting in 3 seconds..
May 5 07:05:12 kernel: ____________________________________________________________________________
