[TUTORIAL] Native Transmission on asuswrt routers through optware
port forwarding
Hi, I'm a bit of a newbie with all this and am having trouble forwarding ports. I wonder if anyone can help? My problem here is that I'm using the asus firmware for an n55u, for which there isn't a custom firmware available. This means I can't follow the forwarding instructions given a few pages back. I'm quite stuck as to what to do. Are there some lines I can put into putty to open ports? I've tried to open 51413 on the router but it doesn't seem to work. The strange thing is that sometimes the port seems to be open, for no apparent reason, and then others not. I'm also using remote transmission.
I've tried forwarding from the router, but I'm not sure it's happy being forwarded to itself??? If I change the port in the remote gui to one that I think is open would that work? Sorry, I'm a bit clueless here!
Paste this lines in terminal:
iptables -I INPUT -p tcp --destination-port 51413 -j ACCEPT
iptables -I INPUT -p udp --destination-port 51413 -j ACCEPT
Unfortunately if you don't have custom firmware with jffs partition enabled, on every router reboot ports will be closed.
Great, thanks a lot for your quick reply and your help. The problem though is that this doesn't work! So I tried an alternative: I used port 44666 which is definitely open, selected that port on the remote GUI, then inserted your script with the above port instead of the default, but still nothing! I've started and stopped transmission several times, but still no luck.I guess I'm doing something wrong?
Also, when I change the port in the remote gui, stopping transmission using putty results in some processes having to be 'killed', it doesn't seem to shut down normally. Sorry, I'm pretty clueless about much of this!
According to the log it should be open, but it isn't, or at least transmission is moving at a snail's pace which suggests a closed port!
initnatpmp succeeded (0) (natpmp.c:72)
transmission-daemon[9761]: Port Forwarding (NAT-PMP) sendpublicaddressrequest succeeded (2) (natpmp.c:72)
transmission-daemon[9761]: Port Forwarding (UPnP) Found Internet Gateway Device "http://192.168.1.1:40136/ctl/IPConn" (upnp.c:200)
Port Forwarding (UPnP) Local Address is "192.168.1.1" (upnp.c:202)
Port Forwarding (UPnP) Port forwarding through "http://192.168.1.1:40136/ctl/IPConn", service "urn:schemas-upnp-org:service:WANIPConnection:1". (local address: 192.168.1.1:44666) (upnp.c:277)
Port Forwarding (UPnP) Port forwarding successful! (upnp.c:280)
Port Forwarding State changed from "Not forwarded" to "Forwarded" (port-forwarding.c:93)
Well, I reinstalled the entire thing, reflashed the router firmware, did all the default resets and etc, formatted to ext3, I did it all. But still the port remained closed (back on 51413 btw). Left it on overnight and all day today, came home to find that all the torrents were finished and that the port is now reporting as open in transmission. Pretty strange I'm sure you will agree. What could be causing this? I didn't change anything. So what did?
How would this Transmission through Entware work on a RT-AC68U?
What kind of performance would one expect? I have 100 Mbit up and down. Will i get similar speeds as if i download and upload from a pc?
Entware only supports MIPS processors. It doesn't support ARM devices like the RT-AC68U and RT-AC56U, you can only use Optware on these two.
Ah ok. Thanks alot for the answer! :) So what kind of performance should one expect? better then download master?
And a sidenote, i cant find the option to check for "Reducing USB 3.0 interference setting" in your or asus firmware, i have looked everywhere. :(
No idea, I don't use either.
It's on the Wireless Professional page, when on the 2.4 GHz band.
ipkg problem
Hello everyone!
I need some help.
I stucked right after the first step during the installation of Transmission on a RT-N66U router (ASUSWRT-Merlin 3.0.0.4.374.39).
This is what I get:
perla@NPeterNAS:/tmp/home/root# ipkg update
Downloading http://ipkg.nslu2-linux.org/feeds/optware/oleg/cross/stable/Packages.gz
Inflating http://ipkg.nslu2-linux.org/feeds/optware/oleg/cross/stable/Packages.gz
Updated list of available packages in /opt/lib/ipkg/lists/optware.oleg
Downloading http://dlcdnet.asus.com/pub/ASUS/wireless/ASUSWRT/Packages.gz
wget: server returned error: HTTP/1.1 404 Not Found
An error ocurred, return value: 1.
Collected errors:
ipkg_download: ERROR: Command failed with return value 1: `wget    -q -P /opt/ipkg-ByF1Hm http://dlcdnet.asus.com/pub/ASUS/wireless/ASUSWRT/Packages.gz'
perla@NPeterNAS:/tmp/home/root# ipkg upgrade
Nothing to be done
Successfully terminated.
perla@NPeterNAS:/tmp/home/root# ipkg install libiconv
Nothing to be done
An error ocurred, return value: 4.
Collected errors:
Cannot find package libiconv.
Check the spelling or perhaps run 'ipkg update'
Any idea what can be wrong?
Download Master was installed an uninstalled as requested. I also tried this to fix ipkg update issue:
app_base_packages.sh sda1
Still can't install libiconv...
Thank you very much for your help in advance!
i dont inistall Transmission on my dsl-n66u. can u help me?
