iunlock
"Plex New Transcoder" running in the background is causing my CPU (i7) to dance at 72C @ 80%+ load!
The max operating temp. for the i7-4790S is 71.35C. Should I be worried?
What are your temperatures of your TVS-x71 NAS?
* If you could, please copy/paste the format below.
Model: TVS-871
CPU Type: i7-4790S
Room Temp: 22C/72F
Idle Temp: 41C
System Temp: 31C
Avg. HD Temp: 30C
Fan Speed: Auto
Avg. Temp during normal tasks: Mid 40C
Highest Temp under 80%-Max Load: 72C
The fans set to "Auto," don't seem to kick in fast enough to cool down the CPU. I'm having to manually set the fans to "High," and it's getting very annoying.
I'm thinking that I have something 'checked,' in the Plex settings that I should 'uncheck.' Perhaps the generating of the thumbnails? I've just added a bunch of movies on there (hundreds) so that's likely the culprit.
Any tips on what to turn off in the Plex settings to avoid this?
Has anyone else hit 72C under max load? Is this normal? Should I be worried?
Anyway to manually change the "Auto," fan speed values within the code to adjust the low, medium and high fan speed trigger? I wish the current manual settings allow you to adjust the fans based on CPU temp and not just System temp.
Thanks and please input your temps in the poll.
***Update:***
Here is a great link for future reference.
https://support.plex.tv/hc/en-us/ar...nscoder-using-my-CPU-when-nothing-is-playing-
Excellent write up about Intel Temp Guide:
http://www.tomshardware.com/forum/id-1800828/intel-temperature-guide.html
Model: TVS-871
CPU Type: i7-4790S
Room Temp: 22C/72F
Idle Temp: 41C
System Temp: 31C
Avg. HD Temp: 30C
Fan Speed: Auto
***Update:***
