Two DHCP routers interconected networks
I just figured out the small top picture is router1. I had to blow up the picture to 200% to kind of read. So what does not work? I need a list of ping tests. If you are connected to the 192.168.1.0 network with a machine can you 192.168.1.52? If you are connected to network 192.168.2.0 can you ping 192.168.1.1? This would be a start.
Network 1 / PC on Network 1:
C:\>ping 192.168.1.1 "ROUTER 1"
Pinging 192.168.1.1 with 32 bytes of data:
Reply from 192.168.1.1: bytes=32 time<1ms TTL=64
Reply from 192.168.1.1: bytes=32 time=1ms TTL=64
Ping statistics for 192.168.1.1:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 1ms, Average = 0ms
C:\>ping 192.168.1.6 "LOOP to same PC"
Pinging 192.168.1.6 with 32 bytes of data:
Reply from 192.168.1.6: bytes=32 time<1ms TTL=128
Ping statistics for 192.168.1.6:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
C:\>ping 192.168.1.52 "ROUTER 2"
Pinging 192.168.1.52 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 192.168.1.52:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
Network 2 / PC on Network 2:
C:\>ping 192.168.2.1 "ROUTER 2"
Pinging 192.168.2.1 with 32 bytes of data:
Reply from 192.168.2.1: bytes=32 time<1ms TTL=64
Reply from 192.168.2.1: bytes=32 time=1ms TTL=64
Ping statistics for 192.168.2.1:
C:\>ping 192.168.2.121 "LOOP to same PC"
Pinging 192.168.2.121 with 32 bytes of data:
Reply from 192.168.2.121: bytes=32 time<1ms TTL=128
Ping statistics for 192.168.2.121:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
You need to figure out why you cannot ping 192.168.1.52 which is the WAN IP address for router2 from the network 192.168.1.0. A machine connected to 192.168.1.0 network should be able to ping an address in its own network. I would assume the firewall is still on or you have a cable or connection problem. Did you try letting router1 assign the IP address with DHCP to router2 WAN interface?
Reagarding cabling issues, is not cable i can plug that cable to ani pc and works ok.
Now, yes i have tried dhcp on router 1 assign automatically ip to router 2 on wan and router 2 get dinamically wan ip. still cant ping the router 2.
and as right now assigned the static ip, router 1 reserve the ip for that router with mac address, and router 2 assigend manually.
I don't have answer for you but you should be able to ping the WAN port from the same network providing the firewall is off. Can you check for a new firmware? Maybe check outstanding issues and see if this is a problem with this router.
Darn... Let me check for router issues.. Ill try with diferrent routers also and ge tback
Firewall is not on as i understand nothing configured on the parental controls/ service block/ port block or schedule in router 1 nor on router 2...
You might post on the E1200 router forum and see if you can turn off the firewall and NAT as and the router as a router. You might also post on the DD-WRT the same thing. I think there is a DD-WRT flash for that router. Cisco would be my preferred way to do this. I would check it first.
Coxhaus, do the net mask have to do anything with this, iam using 255.255.255.0 shouldn't I be using 255.255.252.0
--Never mind.. could not help with anything :p
I guess you figured it out but 255.255.252.0 is wrong. There are several masks which will work and 255.255.255.0 is one of them. The mask defines how big your network is and how many IP addresses are contained in the network.
