uiDivStats uiDivStats 3.x
if you're comfortable editing the script and remembering any time you update it will be overwritten, yes
I forgot to say thank you for all of your hard work on these various projects. It is much appreciated. I was able to alter the Report Time in Diversion that is more to my schedule. Can you tell me where the script is located for UiDivStats? I looked earlier and I was unable to find it.
How can I missed this... Updated during the day and first DB table indexing is done. All good.
Jun 17 00:03:00 RT-AC86U-DBA8 uiDivStats: Trimming records entries from database...
Jun 17 00:03:05 RT-AC86U-DBA8 uiDivStats: Record trimming complete
Jun 17 00:03:05 RT-AC86U-DBA8 uiDivStats: First optimise, this will take a while!
Jun 17 00:03:08 RT-AC86U-DBA8 uiDivStats: Checking database table indexes...
Jun 17 00:06:36 RT-AC86U-DBA8 uiDivStats: Database index checks complete
Jun 17 00:06:37 RT-AC86U-DBA8 uiDivStats: Running nightly database analysis and optimisation...
Jun 17 00:06:48 RT-AC86U-DBA8 uiDivStats: Database analysis and optimisation complete
Jun 17 00:06:49 RT-AC86U-DBA8 uiDivStats: Starting stat full refresh
Jun 17 00:08:09 RT-AC86U-DBA8 uiDivStats: Stats updated successfully
Has anyone run into problems following this upgrade?
No problems during the upgrade I can attribute to uiDivStats - though diversion logging seems to have been in a weird state from a few days before for some reason so had to reboot the router to get that going again.
Big thank you for the domain filter you've added too - that works well and actually allows me to see what is going on now rather than what one noisy device is up to. Quick question on the expected behaviour though - it seems to only take effect when a diversion stats run happens (took me a while to figure out why it wasn't making a difference to the charts after saving the setting). Is that the expected behaviour? (And yes, I may be completely misjudging how/when I thought the UI queried the DB when I ask that! :D)
is this maintenance log supposed to be shown after the upgrade? updated to v3.x a couple of days back but have yet to seen the maintenance logs reflected; assume the maintenance has not happened at all?
The trimming/optimisation log is in the syslog once a day. Do you have this in the cronjob
1 0 * * * /jffs/scripts/uiDivStats trimdb #uiDivStats_trim#
That is what I see in syslog when I did the update.
Jun 16 09:16:20 RT-AC86U-DBA8 uiDivStats: New version of uiDivStats available - updating to v3.0.0
Jun 16 09:16:21 RT-AC86U-DBA8 uiDivStats: New version of uidivstats_www.asp downloaded
Jun 16 09:16:21 RT-AC86U-DBA8 uiDivStats: Mounting uiDivStats WebUI page as user6.asp
Jun 16 09:16:28 RT-AC86U-DBA8 uiDivStats: New version of taildns.tar.gz downloaded
Jun 16 09:16:29 RT-AC86U-DBA8 uiDivStats: uiDivStats successfully updated
The difference in hourly stats update is now there is a start in the log
before
Jun 16 09:01:25 RT-AC86U-DBA8 uiDivStats: Stats updated successfully
after
Jun 16 22:00:01 RT-AC86U-DBA8 uiDivStats: Starting stat update
Jun 16 22:00:33 RT-AC86U-DBA8 uiDivStats: Stats updated successfully
You should see the log entries every night
thats intended behaviour at the moment, as a stat refresh can take longer on some models. wanted to keep the save process quick
I recently installed uiDivStats and am curious about how it deals with IPv6 reporting. Looking at the Query log, for the clients I just see the first 4 groups (e.g. 2a02:c7f:1234:abcd:) so if I need to see where the query originated I need to go to the dnsmasq.log. Is there a way to see the querying client directly from uiDivStats?
Also looking a the weekly stats, for The top 10 noisiest name clients: and Top 10 domains for top 10 clients:, are these looking a the ipv4 traffic only are they also looking at and adjusting for the ipv6 traffic from the same devices?
i dont have a way of testing ipv6, but I believe the charts/stats are ignorant to the protocol version
My diversion stats don't show in the GUI and I have them turned on in Diversion and get a weekly email.
Haven't seen them in a couple of months after router replacement.
Anyone have any ideas why?
if you run option 1 at cli do you get any errors?
no, I got:
Choose an option: 1
Press enter to continue...
no, I got:
Choose an option: 1
I had this issue several moons ago - and it got fixed by running option "uf" in uiDivStats to force an update to the script.
Worth a try as it does no harm [afaik] - and with a browser cache refresh the stats showed up right away in webui.
no, I got:
Choose an option: 1
Ok, please check the contents of /jffs/addons/uiDivStats.d and /opt/share/uiDivStats.d
Particularly looking for the csv directory and of they contain data
There's not one in jffs but is in opt:
I tried it, nothing yet.
ok so the csvs exist, thats good. in your web browser, on the uiDivStats page, press F12 and take a screenshot of any errors listed please
I had cleared the cache, but I didn't see any errors. Not real sure what to look for.
R uiDivStats uiDivStats Asuswrt-Merlin AddOns 2
