I am experiencing similar issues to what is discussed in this post.
LSS, it appears I mistakenly attempted to configure AIMesh with Ethernet connected (device had been set up as an AP). I am now stuck with the recurring message "Unable to add your AIMesh node".
I have reset the nodes multiple times at this point and now re-flashed the firmware (Merlin 386.3). Resets have been via hardware and then again resetting via the GUI, checking the "Initialize all the settings" check box. I have a minimal config of user\password and basic wireless SSID and key.
I have no issues finding the node, but can not get past 1%. I am also not clear which device is having the issue.
I have not tried to reverse the nodes; I would rather clear any issues.
Is there any additional config that I can clear via SSH?
