nyc5gadvocate
I have a frustrating situation where I've tried many things, but I'm still unable to connect my AX200 wireless adapter using 802.11ax to an AiMesh node. The adapter only connects at 802.11n, but not at ac or ax. It is capable of and should connect at 2.4Gbs to my ZenWifi XD6 using 802.11ax, but something fails, and I must manually set the adapter to 802.11n. When set to a newer protocol, the connection seems to be partially established and I see in the router's logs and in Win10 that an IP was assigned via DHCP. However, Win10 connection status says "No internet" and pings of the default gateway (mostly) timeout. Other devices can connect to the same AiMesh XD6 fine and I have a Macbook connecting at 802.11ax 2x2 @ 80Mhz, and an iPhone connected at 802.11ac 2x2. Something after DHCP assignment fails with 802.11ac and ax but works with 802.11n and earlier protocols. Any ideas on what that may be?
I tried a lot of changes to make this work. I set the IP address and DNS servers manually on the AX200 wireless adapter, I also "forgot" the network in Win10, and reset all network devices with no improvement. I tried the older driver version for this adapter from Intel, 22.140 and 22.130, but these changes didn't help. I then performed a hard reset of the AiMesh XD6 and of the main router, but no change made a difference. What else should I try?
