Unable to enable Ethernet Backhaul in XT12
msilva
Hello,
I'm having issues enabling Ethernet Backhaul in XT12 APs using Powerline. Contacted ASUS support, but they were unable to help.
Setup:
- AP1: XT12 connected to Ethernet switch
- AP2: XT12 connected to AiMesh wireless backhaul (trying to connect to a Powerline Devolo Magic 2 connected to same Ethernet switch)
Symptoms:
- AiMesh works fine
- When I try to connect AP2 to the Devolo Powerline, and go to the setup in AP1 to try to enable Ethernet backhaul, it throws the error: "The following node(s) are not connected with an Ethernet cable currently."
- The Powerline is working, I connect it to a laptop and works perfectly
- Sometimes when trying different Ethernet ports in AP2, I get the feeling I'm creating a network loop and my entire network grinds to a halt (it might be AP2 feedbacking the wireless backhaul into the Powerline?)
Questions:
- Haas anyone experienced these issues with wireless backhaul and Powerline?
- Are there specific ports I should use for Ethernet backhaul to work?
- Is it possible that some ports might be creating a network loop? (Is there anyway to enable STP in the XT12?)
Thanks!
Mike
Is the switch a managed switch? If so the Ethernet backhaul will not work. Connect the node WAN port directly to a router LAN port.
L3 in the switch was indeed disabled.
I managed to get it working by enabling the '2.5G WAN only' option. After changing this I was able to enable 'Ethernet backhaul mode'.
The curious part is that after I got it working, I was able to revert the priority back to 'Auto'.
Seems like a bug
