I was just referring to when the router is put in AP mode, a bunch of the menu items disappear. I really like the merlin firmware.
Yes, the connections between the two routers are LAN to LAN ports.
ip r returned the following:
10.16.0.0/24 dev tun22 proto kernel scope link src 10.16.0.1
10.168.2.0/24 dev br0 proto kernel scope link src 10.168.2.11 - is this where the issue is? - should this read: 10.168.2.0/24 dev br0 proto kernel scope link src 10.168.2.1?
127.0.0.0/8 dev lo scope link
This is a screen shot of the WAN menu settings on Router 2 (10.168.2.11). I have disabled WAN, NAT and uPNP, The IP Address under WAN IP Setting is set to 10.168.2.11.
The LAN IP under the LAN menu is set to 10.168.2.11, and the DHCP in the LAN menu is also turned off.
