Unable to remount USB 3.0 Drive
jdpg2
Had this thumb drive mounted without issue, I could see it and select it as a location for my log files ((was still fighting with getting it to write my log files). I removed it and reformatted it and now it wont remount. The router see it as unmounted and when I try the renew option nothing happens. Here is the log when I first plugged it in.
Any ideas?
running merlin 380.63_2 on Asus ac5300
Nov 21 10:42:23 kernel: usb 1-1: new high speed USB device using ehci_hcd and address 4
Nov 21 10:42:23 kernel: scsi2 : usb-storage 1-1:1.0
Nov 21 10:42:24 kernel: scsi 2:0:0:0: Direct-Access PNY USB 3.0 FD PMAP PQ: 0 ANSI: 6
Nov 21 10:42:24 kernel: sd 2:0:0:0: Attached scsi generic sg0 type 0
Nov 21 10:42:24 kernel: sd 2:0:0:0: [sda] 247463936 512-byte logical blocks: (126 GB/118 GiB)
Nov 21 10:42:24 kernel: sd 2:0:0:0: [sda] Write Protect is off
Nov 21 10:42:24 kernel: sd 2:0:0:0: [sda] Assuming drive cache: write through
Nov 21 10:42:24 kernel: sda: sda1
Nov 21 10:42:24 kernel: sd 2:0:0:0: [sda] Attached SCSI removable disk
Nov 21 10:42:24 hotplug[7049]: USB /dev/sda1(unknown) failed to mount at the first try!
Nov 21 10:42:24 usb: USB /dev/sda1(unknown) failed to mount At the first try!
Nov 21 10:42:24 kernel: tfat: fail_safe is enabled
Nov 21 10:42:24 kernel: tntfs info (device sda1, pid 7058): ntfs_fill_super(): fail_safe is enabled
Ahhh.....exFat isn't supported. Not sure why it would work previously.
yea strange.. out of the wrapper it was exFat.. so should I just format it as Fat or NTFS ?
