Hi all, I cannot for the life of me reset my remote XT8 v1 node. I was trying to upgrade to the latest Gnuton version (388.4_0-gnuton0_alpha1) and started, like I always do by upgrading the remote node first. That apparently failed as it never came back up properly and it does not even show as a down node in the GUI. It seemed to be in a funky state where it was pingable from the network and I could even connect via hard-wire to it and surf, but the node itself never showed as being connected in the GUI and if I tried going to the Admin page for the remote node, it said that it couldn't connect to the Parent AP (shown below).
After trying and failing MANY times to factory reset the remote Node, I tried the firmware restoration tool to restore the previous firmware (388.2_2_0-gnuton1). This finally got the IP address back to the shipping default IP of 192.168.50.1, but I still am not able to use the Admin page for it or fully factory reset the device as it still tries to connect to the Parent IP. I've tried a few more resets by powering on with the WPS button pushed, but it appears to be in a reboot loop as it becomes active for about 1 minute, pingable and admin webpage "works" and shows the above screenshot, but then reboots.
Does anyone have advice for getting my unit fully reset so that I can see the following screen and rejoin my Parent node (screenshot from a different unlinked node)?
