I'm running latest 386.1, need to update my signature. I'm checking thru mobile and laptop/tablet mainly wireless devices.Are you still running Beta 4 as your signature shows?
How are you checking those sites? From what device(s)?
I tried a wired laptop as well. No luck. It happens with IE, Chrome and edge.Those mobile/handheld and laptop devices may be the issue? Does using a different browser change the outcome?
I've noticed the last couple of days that a router reboot doesn't load the VPN IP anymore when checking it under whatsmyip.com. It actually shows my real WAN IP.
What's curious is that dnsleak & ipleak tests shows my VPN IP (both IP & DNS match) correctly.
I tried to delete cache/cookies without luck in chrome. I wonder why whatsmyip.com keeps reflecting my real IP and the 2 other sites show VPN IP.
Any ideas, anyone may assist? Thanks!
If I remember correctly I had you set up whatsmyip.com as the bypass check (i.e. check to make sure x3mRouting is bypassing the vpn for packets marked with 0x8000 so those packets should be getting connected directly through WAN) and dnsleak test is to make sure x3mRouting is forcing packets marked with 0x1000 through vpn client 1I've noticed the last couple of days that a router reboot doesn't load the VPN IP anymore when checking it under whatsmyip.com. It actually shows my real WAN IP.
“x3mRouting 1 0 WAN_IP dnsmasq=whatsmyip.com” —> force whatsmyip.com to connect through your wanHi, I am not sure if I understand this correctly. I think the first code below for whatsmyip.com will always route the traffic to WAN port and hence it will show your real WAN IP. For the second code, whatismyip.com will always show your VPN IP?
x3mRouting 1 0 VPN_IP dnsmasq=whatsmyip.com
x3mRouting ALL 1 WAN_IP dnsmasq=whatismyip.com
x3mRouting 1 0 WIP dnsmasq=whatsmyip.com <--> x3mRouting 1 0 WAN_IP dnsmasq=whatsmyip.com
“x3mRouting 1 0 VPN_IP dnsmasq=whatsmyip.com” —> force whatsmyip.com to connect through your vpn“x3mRouting 1 0 VPN_IP dnsmasq=whatsmyip.com” —> force whatsmyip.com to connect through your vpn
“x3mRouting ALL 1 WAN_IP dnsmasq=whatismyip.com”—> force whatismyip.com to connect through your wan
You can see all the rules you have created in /jffs/scripts/nat-start
x3mRouting {src iface} (ALL|1|2|3|4|5)
{dst iface} (0|1|2|3|4|5)
**START: src/dst usage notes**
Valid SRC and DST Combinations
1) VPN Client Routing
- Use this SRC and DST combination to route all IPSET list traffic to a VPN Client:
ALL 1, ALL 2, ALL 3, ALL 4, ALL 5
2) VPN Bypass Routing
- Use this SRC and DST combination to bypass the VPN Client for an IPSET list and route to the WAN interface:
1 0, 2 0, 3 0, 4 0, 5 0
**END: src/dst usage notes**
...snipped...
# Assign the interface for each LAN client by entering #
# the appropriate interface number in the first column #
# 0 = WAN #
# 1 = OVPNC1 #
# 2 = OVPNC2 #
# 3 = OVPNC3 #
# 4 = OVPNC4 #
# 5 = OVPNC5 #
Did switching the rules from -A (append) to -I (insert) fix the issue that comes up when you change your wan dns?I think I figured out why I was leaking. In the past, when I had comcast cable, I used to use xfinity @ home app to allow streaming on my devices, however it would detect a VPN was being used and I had a rule (asnum=AS7016,AS7922 running thru the x3mRouting script) for comcast related stuff to go thru WAN. I have removed the rule and everything is working as intended, so far & after a few reboots!!!
Browserleaks was pointing my network to "AS7922" Comcast Cable Communications.
I'm not sure it's related but this seems to be working now.
You are correct I got those backwards. “0 1” looks for traffic pointed at the vpn and redirects it to the Wan interface. ALL 1 looks for traffic at all interfaces and redirects it to the vpn client 1 interface.“x3mRouting 1 0 VPN_IP dnsmasq=whatsmyip.com” —> force whatsmyip.com to connect through your vpn
I thought it means source interface 1(OVPNC1) to destination interface 0 (WAN)?
Src and Dst combination 1 0 matches no 2) VPN bypass routing. Meaning it bypass VPN client 1 and routes to WAN. Does this mean I should see my WAN IP when i visit whatsmyip.com?
x3mRouting {src iface} (ALL|1|2|3|4|5) {dst iface} (0|1|2|3|4|5) **START: src/dst usage notes** Valid SRC and DST Combinations 1) VPN Client Routing - Use this SRC and DST combination to route all IPSET list traffic to a VPN Client: ALL 1, ALL 2, ALL 3, ALL 4, ALL 5 2) VPN Bypass Routing - Use this SRC and DST combination to bypass the VPN Client for an IPSET list and route to the WAN interface: 1 0, 2 0, 3 0, 4 0, 5 0 **END: src/dst usage notes** ...snipped...
######################################################## # Assign the interface for each LAN client by entering # # the appropriate interface number in the first column # # 0 = WAN # # 1 = OVPNC1 # # 2 = OVPNC2 # # 3 = OVPNC3 # # 4 = OVPNC4 # # 5 = OVPNC5 # #########################################################
It still does the same. I kept the rules with the change ( -I versus - A) and I have not seen anything hiccups running it this way. Should I switch back to -A (append)? Did you see @Martineau post earlier...not sure if this would help?Did switching the rules from -A (append) to -I (insert) fix the issue that comes up when you change your wan dns?
I can’t get this stupid comment thing to work and I’m wary of removing rules based on their rule number because of the potential to remove the wrong rules. I have not seen anyone else using the mangle table in the output chain but I would like to get an exact rule match so I know those are the only rules that can possibly be removed.
modprobe xt_comment
iptables -A FORWARD -s 172.16.55.2,172.16.55.43 -d 123.45.6.7 -j DROP -m comment --comment "KIDS"
iptables -A FORWARD -s 172.16.55.99 -d 123.45.6.99 -j DROP -m comment --comment "KIDS"
iptables-save | grep "KIDS" | sed 's/^-A/iptables -D/' | while read CMD;do $CMD;done
iptables --line -t filter -nvL FORWARD
<snip>
10 0 0 DROP all -- * * 172.16.55.2 123.45.6.7 /* KIDS */
11 0 0 DROP all -- * * 172.16.55.43 123.45.6.7 /* KIDS */
12 0 0 DROP all -- * * 172.16.55.99 123.45.6.99 /* KIDS */
-A FORWARD -s 172.16.55.2/32 -d 123.45.6.7/32 -m comment --comment KIDS -j DROP
-A FORWARD -s 172.16.55.43/32 -d 123.45.6.7/32 -m comment --comment KIDS -j DROP
-A FORWARD -s 172.16.55.99/32 -d 123.45.6.99/32 -m comment --comment KIDS -j DROP
iptables -D FORWARD -s 172.16.55.2/32 -d 123.45.6.7/32 -m comment --comment KIDS -j DROP
iptables -D FORWARD -s 172.16.55.43/32 -d 123.45.6.7/32 -m comment --comment KIDS -j DROP
iptables -D FORWARD -s 172.16.55.99/32 -d 123.45.6.99/32 -m comment --comment KIDS -j DROP
Yeah I did see that yesterday. I haven’t really looked at what was posted but I made a note to look at that first when I get a second to pull this back up. This week has just been crazy and I haven’t had any extra time between school and work.It still does the same. I kept the rules with the change ( -I versus - A) and I have not seen anything hiccups running it this way. Should I switch back to -A (append)? Did you see @Martineau post earlier...not sure if this would help?
http://www.snbforums.com/threads/unbound-dns-vpn-client-w-policy-rules.67370/post-658109
Fantastic! This is exactly what I’m trying to do. As I stated in a previous post I haven’t really had time to dig into this. I briefly tried to add “-m comment --comment “xxx”” to the rule creation but it got rejected with “no matching rule” or something like that so I’m not sure if I just made a syntax error or if there is some conflict but either way I need to dig in a bit moreBrief tutorial..copy and paste for testing on command line
Tag multiple devices (e.g. two) that are to be 'categorised' as "KIDS" with a single rule request
then perhaps sometime later auto block another device/destination combo (say when DHCP allocation of LAN IP address is detected)Code:modprobe xt_comment iptables -A FORWARD -s 172.16.55.2,172.16.55.43 -d 123.45.6.7 -j DROP -m comment --comment "KIDS"
Code:iptables -A FORWARD -s 172.16.55.99 -d 123.45.6.99 -j DROP -m comment --comment "KIDS"
Perform the mass delete of the "KIDS" 'category' (without knowing the actual detail/number of rules etc.)
Code:iptables-save | grep "KIDS" | sed 's/^-A/iptables -D/' | while read CMD;do $CMD;done
TL;DR
If you want to see the "KIDS" 'category' rules BEFORE the mass delete, this should help in understanding how it works
Generic list of rules
Code:iptables --line -t filter -nvL FORWARD <snip> 10 0 0 DROP all -- * * 172.16.55.2 123.45.6.7 /* KIDS */ 11 0 0 DROP all -- * * 172.16.55.43 123.45.6.7 /* KIDS */ 12 0 0 DROP all -- * * 172.16.55.99 123.45.6.99 /* KIDS */
Now explicitly list ALL rules by 'category' (without knowing the actual number of rules etc.)
Code:iptables-save | grep "KIDS" -A FORWARD -s 172.16.55.2/32 -d 123.45.6.7/32 -m comment --comment KIDS -j DROP -A FORWARD -s 172.16.55.43/32 -d 123.45.6.7/32 -m comment --comment KIDS -j DROP -A FORWARD -s 172.16.55.99/32 -d 123.45.6.99/32 -m comment --comment KIDS -j DROP
Prepare for mass delete by 'category' (without knowing the actual number of rules etc.)
Code:iptables-save | grep "KIDS" | sed 's/^-A/iptables -D/' iptables -D FORWARD -s 172.16.55.2/32 -d 123.45.6.7/32 -m comment --comment KIDS -j DROP iptables -D FORWARD -s 172.16.55.43/32 -d 123.45.6.7/32 -m comment --comment KIDS -j DROP iptables -D FORWARD -s 172.16.55.99/32 -d 123.45.6.99/32 -m comment --comment KIDS -j DROP
Perhaps you needed theFantastic! This is exactly what I’m trying to do. As I stated in a previous post I haven’t really had time to dig into this. I briefly tried to add “-m comment --comment “xxx”” to the rule creation but it got rejected with “no matching rule” or something like that so I’m not sure if I just made a syntax error or if there is some conflict but either way I need to dig in a bit more
modprobe xt_comment
?I have not done that so that seems likely lol. Thanks for your input I really appreciate it. I’m trying to wrap my head around everything but Linux/bash is such a beast. Just too many ways to same tasks. I feel like such a script kiddie right now but I’m glad to have a community that can push me in the right direction.Perhaps you needed themodprobe xt_comment
I made some time today to work on this. A real quick question do modprobe directives persist after reboots? Should I put this in a setup function that only runs on initial setup?Perhaps you needed themodprobe xt_comment
Yes I useI made some time today to work on this. A real quick question do modprobe directives persist after reboots? Should I put this in a setup function that only runs on initial setup?
init-start
rather than include/execute modprobe xt_comment
in the individual scripts.Welcome To SNBForums
