Connected to 192.168.1.1.
login as: admin
admin@192.168.1.1's password: ***********
ASUSWRT-Merlin GT-AX6000 386.6_0 Wed Apr 20 01:45:24 UTC 2022
admin@GT-AX6000-AD78:/tmp/home/root# ls -l $(which sh)
lrwxrwxrwx 1 admin root 7 May 11 21:20 /opt/bin/sh -> /bin/sh
admin@GT-AX6000-AD78:/tmp/home/root# wget --timeout=10 --tries=3 --retry-connrefused -qO - "
https://bin.entware.net/aarch64-k3.10
Info: Checking for prerequisites and creating folders...
Warning: Folder /opt exists!
Warning: Folder /opt/bin exists!
Warning: If something goes wrong please clean /opt folder and try again.
Warning: Folder /opt/etc exists!
Warning: Folder /opt/lib/opkg exists!
Warning: Folder /opt/tmp exists!
Warning: Folder /opt/var/lock exists!
Info: Opkg package manager deployment...
--2022-05-13 18:51:32--
http://bin.entware.net/aarch64-k3.10/installer/opkg
Resolving bin.entware.net... 188.114.97.3, 188.114.96.3, 2a06:98c1:3120::3, ...
Connecting to bin.entware.net|188.114.97.3|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 860008 (840K) [application/octet-stream]
Saving to: '/opt/bin/opkg'
/opt/bin/opkg 100%[=================================================================================
2022-05-13 18:51:32 (13.9 MB/s) - '/opt/bin/opkg' saved [860008/860008]
http://bin.entware.net/aarch64-k3.10/installer/opkg.conf
Resolving bin.entware.net... 188.114.96.3, 188.114.97.3, 2a06:98c1:3121::3, ...
Connecting to bin.entware.net|188.114.96.3|:80... connected.
Length: 175 [application/octet-stream]
Saving to: '/opt/etc/opkg.conf'
/opt/etc/opkg.conf 100%[=================================================================================
2022-05-13 18:51:32 (20.6 MB/s) - '/opt/etc/opkg.conf' saved [175/175]
Info: Basic packages installation...
Downloading
http://bin.entware.net/aarch64-k3.10/Packages.gz
Updated list of available packages in /opt/var/opkg-lists/entware
Package entware-opt (227000-3) installed in root is up to date.
Info: Congratulations!
Info: If there are no errors above then Entware was successfully initialized.
Info: Add /opt/bin & /opt/sbin to $PATH variable
Info: Add "/opt/etc/init.d/rc.unslung start" to startup script for Entware services to start
Info: Found a Bug? Please report at
https://github.com/Entware/Entware/issues
