Undetected SSD drive via USB3, works in USB2
SnakeByte
I've got a Samsung 840 Pro 256GB SSD drive plugged into a Seagate FA GoFlex Desk USB3 adapter.
When plugging into the USB2 port on the ASUS RT-AC68U router (Running 3.0.0.4.374.38_1), it detects and mounts the drive without issue:
Jan 13 22:26:24 kernel: usb 2-2: new high speed USB device using ehci_hcd and address 74
Jan 13 22:26:24 kernel: scsi1 : usb-storage 2-2:1.0
Jan 13 22:26:25 kernel: scsi 1:0:0:0: Direct-Access Seagate FA GoFlex Desk D0B PQ: 0 ANSI: 0
Jan 13 22:26:25 kernel: sd 1:0:0:0: Attached scsi generic sg0 type 0
Jan 13 22:26:25 kernel: sd 1:0:0:0: [sda] 500118191 512-byte logical blocks: (256 GB/238 GiB)
Jan 13 22:26:25 kernel: sd 1:0:0:0: [sda] Write Protect is off
Jan 13 22:26:25 kernel: sd 1:0:0:0: [sda] Assuming drive cache: write through
Jan 13 22:26:25 kernel: sda: sda1
Jan 13 22:26:25 kernel: sd 1:0:0:0: [sda] Attached SCSI disk
Jan 13 22:26:25 hotplug[12924]: USB ext4 fs at /dev/sda1 mounted on /tmp/mnt/ASUS_SSD
Jan 13 22:26:25 kernel: EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: user_xattr
However, if I dismount and plug the unit into the USB3 port, bad juju:
Jan 13 22:36:46 kernel: scsi0 : usb-storage 1-1:1.0
Jan 13 22:36:47 kernel: scsi 0:0:0:0: Direct-Access Seagate FA GoFlex Desk D0B PQ: 0 ANSI: 0
Jan 13 22:36:47 kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0
Jan 13 22:36:47 kernel: sd 0:0:0:0: [sda] 500118191 512-byte logical blocks: (256 GB/238 GiB)
Jan 13 22:36:47 kernel: xhci_hcd 0000:00:0b.0: WARN: Stalled endpoint
Jan 13 22:36:49 kernel: ohci_hcd 0000:00:0a.0: USB bus 3 deregistered
Jan 13 22:36:50 kernel: xhci_hcd 0000:00:0b.0: xHCI Host Controller
Jan 13 22:36:50 kernel: xhci_hcd 0000:00:0b.0: new USB bus registered, assigned bus number 1
Jan 13 22:36:50 kernel: xhci_hcd 0000:00:0b.0: irq 112, io mem 0x18023000
Jan 13 22:36:50 kernel: xhci_hcd 0000:00:0b.0: Failed to enable MSI-X
Jan 13 22:36:50 kernel: xhci_hcd 0000:00:0b.0: failed to allocate MSI entry
Jan 13 22:36:50 kernel: usb usb1: No SuperSpeed endpoint companion for config 1 interface 0 altsetting 0 ep 129: using
Jan 13 22:36:57 kernel: hub 2-0:1.0: unable to enumerate USB device on port 1
Jan 13 22:36:59 kernel: hub 2-0:1.0: unable to enumerate USB device on port 1
Jan 13 22:37:02 kernel: hub 2-0:1.0: unable to enumerate USB device on port 1
Jan 13 22:37:04 kernel: hub 2-0:1.0: unable to enumerate USB device on port 1
Jan 13 22:37:06 kernel: hub 2-0:1.0: unable to enumerate USB device on port 1
Jan 13 22:37:09 kernel: hub 2-0:1.0: unable to enumerate USB device on port 1
Jan 13 22:37:11 kernel: hub 2-0:1.0: unable to enumerate USB device on port 1
Jan 13 22:37:14 kernel: hub 2-0:1.0: unable to enumerate USB device on port 1
Jan 13 22:37:16 kernel: hub 2-0:1.0: unable to enumerate USB device on port 1
Jan 13 22:37:18 kernel: hub 2-0:1.0: unable to enumerate USB device on port 1
I take it ASUS is still working out the bugs with the USB3 stuff? I know their latest beta has some USB3 fixes and those haven't been integrated with the merlin builds yet?
Seagate USB drive
I had the same problem. My Windows7 system detects it as USB3.0 but the RT-AC68U does not. I had the same experience you did. Fortunately I had another drive (WD) that the router detected as a USB3.0 device.
On another site someone posted that the issue was with the Seagate drive. There is an issue with its detection of a USB3.0 port connection.
Seagate=FAIL
WD=SUCCESS
Seagate=FAIL
WD=SUCCESS
I tried a different USB 3 interface with that Samsung SSD drive, but still no love, so this isn't just a Seagate issue.
Hopefully RMerlin's next build will include some of the recent ASUS fixes (and hopefully those fixes will help this issue).
