Unidentified Network Issue.
Try this. It's instructions on how to install Knoppix, a open source troubleshooting Linux distro, on a USB and then boot from is on your laptop. You don't need to know anything about how Knoppix works, just see if you can boot with it and get online. If not, it's a problem with the NIC, my guess would be one or more of the pins for the ethernet twisted pair is bent or damaged and the NIC can't fully establish a duplexed connection on it. If you DO get online with Knoppix, then it's a driver issue, and we can look back into that.
If it does end up being a driver issue (which I am doubting at this time) then make sure to update your drivers. Your screenshot shows you running 12.15.25.6712 while the latest for Windows 10 are 22.7.1 and AsRock suggest at least 20.2. So you are atleast 8 revisions behind. What's odd is that the driver date doesn't match the driver version. My guess is that's the default hardware driver Windows installs for Intel. You want to install the one from Intel instead.
Oddly enough, installing the most "current" driver from intel actually is much older than the driver that was on the computer previously. SS for clarification
Ahh, ok, I think I understand. I am looking at the Intel driver installer version, but the driver is showing the actual NIC driver version. So how does one find out what the latest intel NIC driver is? I don't like when manufacturers do "install packages". AMD does it too and it's annoying IMO. Any Intel experts out there?
In the meantime, you think you want to try the Knoppix USB? There are other versions and ways of putting in on a CD if that is easier. If you have system restore and can restore back before the problem happened, that might be a option too. It depends on how nuclear you want to go before isolating it's a hardware problem or not for sure.
I’m currently cleaning up a USB to install the Linux os on it. I also ordered an external Ethernet adapter from amazon as well lol. 1 way or another we’re gonna solve this madness
Yea, sorry it's taking longer then I thought. I called GG too early. :( I really thought we had it when I saw two ethernet into the bridged gateway.
Getting this when following the above listed steps ? do i need to download a .iso first ?
I haven't actually used that installer, it was just the first one that came up in google. I think you need to check the "Download link" box to download the ISO from pendrivelinux.com. If you can't get it to work, try the official steps instead.
A couple other things I was thinking you could try while working on that. They are things that only work 1:100,000 but they are easy to do so worth a shot. First, as stupid as this sounds, try turning the ethernet around. Another words, unplug the RJ45 from the PC and plug that end into the router instead, and visa versa. This tests if one of the RJ45 male pins pushed down slightly on the female port in the NIC. This can happen over time or during troubleshooting from unplugging/replugging the ethernet over and over.
The other thing to try is to have the desktop plugged into a different electrical wall socket then the router. Not just a different power strip or different outlet on the two outlet face plate, but a entirly different face plate/outlet. This isolates for any possible power or ground issue. Maybe the reason why laptops are working plugged into the ethernet is because they run on battery and not ground connected AC like a desktop.
Last, unplug the 3 USB from the PC and reboot. This is assuming you don't need the keyboard/mouse to log in. If you do, try booting into BIOS and seeing the state of ethernet there. Depends on the BIOS, but some have ethernet options related to network boot. The reason your testing without the USB is incase there is some kind of power drain issue where the board doesn't have enough power for the NIC. Highly unlikely, but worth a shot.
Not sure if I’m happy about this or not but even running knoppix the computer wouldn’t connect to the Ethernet adapter. Going to say it’s safely a NIC issue, which means either a new motherboard or a external adapter
Have you looked at the pins inside the female ethernet jack on the NIC? Does anything look bent/burned/dusty/damaged? Also, do you happen to have a 3foot or less ethernet you can try with? It seems to be able to atleast make a 10Mbps connection, so maybe with a shorter ethernet it can make a 100Mbps connection rate. You could also play around with the manual duplex modes. However in the end, that will only show you what the problem is and not fix it.
When you say wouldn't connect, do you mean it wasn't getting a IP, wasn't seeing the ethernet plugged in, or wasn't seeing the NIC adapter at all?
Does the connection change if you disconnect the ethernet from the port? Like if you boot without the ethernet plugged in, does the NIC show as disconnected but otherwise normal? Also, is the ethernet in use a normal premade CAT5e? Have you tried a different ethernet cord? Even if that one was confirmed working with the laptop the ethernet could still be damaged somehow that only effects certain kind of link negotiation. The fact that it's even able to try to identify the network makes me think Knoppix can talk to the NIC, so it doesn't sound like the chip for the NIC itself is the issue. If anything, the problem seems more with the port.
Could you give some more context on when this problem began? It's looking more like a hardware issue, but then I thought the problem started around the upgrade to Windows 10. Did you make any other hardware changes when you upgraded to Windows 10? Do you O.C. your CPU or RAM? Also, any other odd problems around the time your lost ethernet connection? For instance, you said you used a USB microphone, is that because the internal microphone I/O stopped working? Any storms, brownouts, or issues with the power to the PC?
If I disconnect from the port I get the “network cable is unplugged” error. It started right after I upgraded to windows 10. None of my hardware is currently OC’ed. Also I use a usb headset because im an avid pc gamer and prefer that over the standard one.
Do you have standard microphone or stereo headset you can try on one of the red/green/blue sound I/O underneath the ethernet port on the back of the desktop? If there was some kind of blown transistor or damage from a surge, you would probably literally hear it from those ports as well. It might sound like a low background hum or sharp specks of static. If you confirm that is having issues, then buying a external NIC might not be worth the time since the whole motherboard might die soon.
Is the desktop home built. store bought, or something inbetween? It looks to use a high end motherboard yet I see the Windows sticker on it like a retail unit. BTW, you might want to edit that picture just to make sure no one sneaky grabs it. Or just take the photo down as it isn't relevant anymore to the issue. The picture of the back is still helpful though. Could you take a closer picture of the inside of the ethernet port with a flashlight? Or maybe one of the motherboard itself? I am morbidly curious by nature, but I understand if you prefer to work with what has been posted already.
Also can you show some of the other tabs as seen in the picture you posted here? Specifically the Link Speed tab but there looks like a lot of advanced settings. If this IS directly related to the Windows 10 update, maybe one of those settings conflicts or was changed with a MS update. If you see any way to "reset to defaults" anywhere in the UI, try that.
Also, it might help to look at a Minitoolbox log. It's a tool from BC.com that collects logs and some other data for troubleshooting. The ones I would be curious about are IP configuration, winsock, last 10 errors, devices with problems, and restore points (for update timestamps). A list of installed programs would help too, but is a bit more revealing in a privacy way.
PS. Are there any rules about what I am allowed to ask people to run or what they are allowed to post? I know some forums frown on huge log posts.
========================= IP Configuration: ================================
Realtek RTL8723AU Wireless LAN 802.11n USB 2.0 Network Adapter = Wi-Fi (Connected)
Intel(R) Ethernet Connection I217-V = Ethernet (Connected)
Broadcom 802.11ac Network Adapter = Wi-Fi 2 (Media disconnected)
Bluetooth Device (Personal Area Network) = Bluetooth Network Connection 4 (Media disconnected)
# IPv4 Configuration
pushd interface ipv4
reset
set global icmpredirects=enabled
set interface interface="Bluetooth Network Connection 3" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Wi-Fi 2" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Bluetooth Network Connection 4" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Local Area Connection* 17" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Wi-Fi" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Local Area Connection* 13" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Ethernet" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
popd
# End of IPv4 configuration
Windows IP Configuration
Host Name . . . . . . . . . . . . : Christopher
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : elp.rr.com
Wireless LAN adapter Local Area Connection* 17:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #5
Physical Address. . . . . . . . . : 26-0A-64-B0-AB-52
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Wireless LAN adapter Wi-Fi 2:
Description . . . . . . . . . . . : Broadcom 802.11ac Network Adapter
Physical Address. . . . . . . . . : 24-0A-64-B0-AB-52
Wireless LAN adapter Wi-Fi:
Connection-specific DNS Suffix . : elp.rr.com
Description . . . . . . . . . . . : Realtek RTL8723AU Wireless LAN 802.11n USB 2.0 Network Adapter
Physical Address. . . . . . . . . : 20-16-D8-32-B8-C7
Link-local IPv6 Address . . . . . : fe80::6569:16c0:a106:b914%19(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.104(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Monday, October 30, 2017 4:50:00 PM
Lease Expires . . . . . . . . . . : Tuesday, October 31, 2017 4:50:01 PM
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 337647320
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1F-40-0E-7B-24-0A-64-B0-AB-52
DNS Servers . . . . . . . . . . . : 2605:6000:1304:a00f:c256:27ff:fe4c:870e
192.168.1.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Connection-specific DNS Suffix Search List :
elp.rr.com
Ethernet adapter Ethernet:
Description . . . . . . . . . . . : Intel(R) Ethernet Connection I217-V
Physical Address. . . . . . . . . : BC-5F-F4-FD-25-45
Link-local IPv6 Address . . . . . : fe80::9406:e939:1f86:2853%23(Preferred)
Autoconfiguration IPv4 Address. . : 169.254.40.83(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.0.0
DHCPv6 IAID . . . . . . . . . . . : 79454196
DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
Ethernet adapter Bluetooth Network Connection 4:
Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network) #3
Physical Address. . . . . . . . . : 24-0A-64-9F-8C-3E
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
DNS request timed out.
timeout was 2 seconds.
Server: UnKnown
Address: 2605:6000:1304:a00f:c256:27ff:fe4c:870e
Pinging google.com [172.217.2.238] with 32 bytes of data:
Reply from 172.217.2.238: bytes=32 time=28ms TTL=54
Reply from 172.217.2.238: bytes=32 time=32ms TTL=54
Ping statistics for 172.217.2.238:
Packets: Sent = 2, Received = 2, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 28ms, Maximum = 32ms, Average = 30ms
Server: UnKnown
Pinging yahoo.com [98.139.180.149] with 32 bytes of data:
Reply from 98.139.180.149: bytes=32 time=82ms TTL=49
Reply from 98.139.180.149: bytes=32 time=77ms TTL=49
Ping statistics for 98.139.180.149:
Minimum = 77ms, Maximum = 82ms, Average = 79ms
Pinging 127.0.0.1 with 32 bytes of data:
Reply from 127.0.0.1: bytes=32 time<1ms TTL=128
Ping statistics for 127.0.0.1:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
Interface List
25...26 0a 64 b0 ab 52 ......Microsoft Wi-Fi Direct Virtual Adapter #5
2...24 0a 64 b0 ab 52 ......Broadcom 802.11ac Network Adapter
19...20 16 d8 32 b8 c7 ......Realtek RTL8723AU Wireless LAN 802.11n USB 2.0 Network Adapter
23...bc 5f f4 fd 25 45 ......Intel(R) Ethernet Connection I217-V
26...24 0a 64 9f 8c 3e ......Bluetooth Device (Personal Area Network) #3
1...........................Software Loopback Interface 1
3...00 00 00 00 00 00 00 e0 Teredo Tunneling Pseudo-Interface
IPv4 Route Table
Active Routes:
Network Destination Netmask Gateway Interface Metric
0.0.0.0 0.0.0.0 192.168.1.1 192.168.1.104 50
127.0.0.0 255.0.0.0 On-link 127.0.0.1 331
127.0.0.1 255.255.255.255 On-link 127.0.0.1 331
127.255.255.255 255.255.255.255 On-link 127.0.0.1 331
169.254.0.0 255.255.0.0 On-link 169.254.40.83 311
169.254.40.83 255.255.255.255 On-link 169.254.40.83 311
169.254.255.255 255.255.255.255 On-link 169.254.40.83 311
192.168.1.0 255.255.255.0 On-link 192.168.1.104 306
192.168.1.104 255.255.255.255 On-link 192.168.1.104 306
192.168.1.255 255.255.255.255 On-link 192.168.1.104 306
224.0.0.0 240.0.0.0 On-link 127.0.0.1 331
224.0.0.0 240.0.0.0 On-link 192.168.1.104 306
224.0.0.0 240.0.0.0 On-link 169.254.40.83 311
255.255.255.255 255.255.255.255 On-link 127.0.0.1 331
255.255.255.255 255.255.255.255 On-link 192.168.1.104 306
255.255.255.255 255.255.255.255 On-link 169.254.40.83 311
Persistent Routes:
None
IPv6 Route Table
Active Routes:
If Metric Network Destination Gateway
1 331 ::1/128 On-link
19 306 fe80::/64 On-link
23 311 fe80::/64 On-link
19 306 fe80::6569:16c0:a106:b914/128
On-link
23 311 fe80::9406:e939:1f86:2853/128
On-link
1 331 ff00::/8 On-link
19 306 ff00::/8 On-link
23 311 ff00::/8 On-link
Persistent Routes:
None
========================= Winsock entries =====================================
Catalog5 01 C:\WINDOWS\SysWOW64\napinsp.dll [54784] (Microsoft Corporation)
Catalog5 02 C:\WINDOWS\SysWOW64\pnrpnsp.dll [70144] (Microsoft Corporation)
Catalog5 03 C:\WINDOWS\SysWOW64\pnrpnsp.dll [70144] (Microsoft Corporation)
Catalog5 04 C:\WINDOWS\SysWOW64\NLAapi.dll [63488] (Microsoft Corporation)
Catalog5 05 C:\WINDOWS\SysWOW64\mswsock.dll [305568] (Microsoft Corporation)
Catalog5 06 C:\WINDOWS\SysWOW64\winrnr.dll [23040] (Microsoft Corporation)
Catalog5 07 C:\WINDOWS\SysWOW64\wshbth.dll [50688] (Microsoft Corporation)
Catalog9 01 C:\WINDOWS\SysWOW64\mswsock.dll [305568] (Microsoft Corporation)
Catalog9 02 C:\WINDOWS\SysWOW64\mswsock.dll [305568] (Microsoft Corporation)
Catalog9 03 C:\WINDOWS\SysWOW64\mswsock.dll [305568] (Microsoft Corporation)
Catalog9 04 C:\WINDOWS\SysWOW64\mswsock.dll [305568] (Microsoft Corporation)
Catalog9 05 C:\WINDOWS\SysWOW64\mswsock.dll [305568] (Microsoft Corporation)
Catalog9 06 C:\WINDOWS\SysWOW64\mswsock.dll [305568] (Microsoft Corporation)
Catalog9 07 C:\WINDOWS\SysWOW64\mswsock.dll [305568] (Microsoft Corporation)
Catalog9 08 C:\WINDOWS\SysWOW64\mswsock.dll [305568] (Microsoft Corporation)
Catalog9 09 C:\WINDOWS\SysWOW64\mswsock.dll [305568] (Microsoft Corporation)
Catalog9 10 C:\WINDOWS\SysWOW64\mswsock.dll [305568] (Microsoft Corporation)
Catalog9 11 C:\WINDOWS\SysWOW64\mswsock.dll [305568] (Microsoft Corporation)
Catalog9 12 C:\WINDOWS\SysWOW64\mswsock.dll [305568] (Microsoft Corporation)
Catalog9 13 C:\WINDOWS\SysWOW64\mswsock.dll [305568] (Microsoft Corporation)
x64-Catalog5 01 C:\Windows\System32\napinsp.dll [66560] (Microsoft Corporation)
x64-Catalog5 02 C:\Windows\System32\pnrpnsp.dll [85504] (Microsoft Corporation)
x64-Catalog5 03 C:\Windows\System32\pnrpnsp.dll [85504] (Microsoft Corporation)
x64-Catalog5 04 C:\Windows\System32\NLAapi.dll [79872] (Microsoft Corporation)
x64-Catalog5 05 C:\Windows\System32\mswsock.dll [358600] (Microsoft Corporation)
x64-Catalog5 06 C:\Windows\System32\winrnr.dll [31232] (Microsoft Corporation)
x64-Catalog5 07 C:\Windows\System32\wshbth.dll [63488] (Microsoft Corporation)
x64-Catalog9 01 C:\Windows\System32\mswsock.dll [358600] (Microsoft Corporation)
x64-Catalog9 02 C:\Windows\System32\mswsock.dll [358600] (Microsoft Corporation)
x64-Catalog9 03 C:\Windows\System32\mswsock.dll [358600] (Microsoft Corporation)
x64-Catalog9 04 C:\Windows\System32\mswsock.dll [358600] (Microsoft Corporation)
x64-Catalog9 05 C:\Windows\System32\mswsock.dll [358600] (Microsoft Corporation)
x64-Catalog9 06 C:\Windows\System32\mswsock.dll [358600] (Microsoft Corporation)
x64-Catalog9 07 C:\Windows\System32\mswsock.dll [358600] (Microsoft Corporation)
x64-Catalog9 08 C:\Windows\System32\mswsock.dll [358600] (Microsoft Corporation)
x64-Catalog9 09 C:\Windows\System32\mswsock.dll [358600] (Microsoft Corporation)
x64-Catalog9 10 C:\Windows\System32\mswsock.dll [358600] (Microsoft Corporation)
x64-Catalog9 11 C:\Windows\System32\mswsock.dll [358600] (Microsoft Corporation)
x64-Catalog9 12 C:\Windows\System32\mswsock.dll [358600] (Microsoft Corporation)
x64-Catalog9 13 C:\Windows\System32\mswsock.dll [358600] (Microsoft Corporation)
========================= Event log errors: ===============================
Application errors:
Error: (10/30/2017 05:10:02 PM) (Source: Application Error) (User: )
Description: Faulting application name: svchost.exe, version: 10.0.15063.0, time stamp: 0x4c9dbd90
Faulting module name: KERNEL32.DLL, version: 10.0.15063.296, time stamp: 0xab7aae51
Exception code: 0xc0000005
Fault offset: 0x00016850
Faulting process id: 0x271c
Faulting application start time: 0xsvchost.exe0
Faulting application path: svchost.exe1
Faulting module path: svchost.exe2
Report Id: svchost.exe3
Faulting package full name: svchost.exe4
Faulting package-relative application ID: svchost.exe5
Error: (10/30/2017 05:05:02 PM) (Source: Application Error) (User: )
Faulting process id: 0x1fc4
Error: (10/30/2017 05:00:01 PM) (Source: Application Error) (User: )
Faulting process id: 0x31c4
Error: (10/30/2017 04:55:01 PM) (Source: Application Error) (User: )
Faulting process id: 0x26f0
Error: (10/30/2017 04:51:05 PM) (Source: Perflib) (User: )
Description: rdyboost4
Error: (10/30/2017 04:49:58 PM) (Source: Application Error) (User: )
Faulting process id: 0xcf4
Error: (10/29/2017 07:24:16 PM) (Source: Application Error) (User: )
Faulting process id: 0x2194
Error: (10/29/2017 07:19:16 PM) (Source: Application Error) (User: )
Faulting process id: 0x33e8
Error: (10/29/2017 07:14:16 PM) (Source: Application Error) (User: )
Faulting process id: 0x1bac
Error: (10/29/2017 07:09:16 PM) (Source: Application Error) (User: )
Faulting process id: 0x1e28
System errors:
Error: (10/30/2017 05:10:02 PM) (Source: Service Control Manager) (User: )
Description: The Local Driver Service service terminated unexpectedly. It has done this 1 time(s). The following corrective action will be taken in 300000 milliseconds: Restart the service.
Error: (10/30/2017 05:05:02 PM) (Source: Service Control Manager) (User: )
Error: (10/30/2017 05:00:02 PM) (Source: Service Control Manager) (User: )
Error: (10/30/2017 04:55:01 PM) (Source: Service Control Manager) (User: )
Error: (10/30/2017 04:50:21 PM) (Source: DCOM) (User: NT AUTHORITY)
Description: application-specificLocalActivation{6B3B8D23-FA8D-40B9-8DBD-B950333E2C52}{4839DDB7-58C2-48F5-8283-E1D1807D0D7D}NT AUTHORITYLOCAL SERVICES-1-5-19LocalHost (Using LRPC)UnavailableUnavailable
Error: (10/30/2017 04:50:01 PM) (Source: Service Control Manager) (User: )
Error: (10/30/2017 04:49:57 PM) (Source: Service Control Manager) (User: )
Description: The CldFlt service failed to start due to the following error:
%%50 = The request is not supported.
Error: (10/29/2017 07:24:17 PM) (Source: Service Control Manager) (User: )
Error: (10/29/2017 07:19:16 PM) (Source: Service Control Manager) (User: )
Microsoft Office Sessions:
Error: (10/30/2017 05:10:02 PM) (Source: Application Error)(User: )
Description: svchost.exe10.0.15063.04c9dbd90KERNEL32.DLL10.0.15063.296ab7aae51c000000500016850271c01d351d437178db3C:\WINDOWS\SysWOW64\svchost.exeC:\WINDOWS\System32\KERNEL32.DLL235782c5-f083-4480-b7f8-3cc31700b3be
Error: (10/30/2017 05:05:02 PM) (Source: Application Error)(User: )
Description: svchost.exe10.0.15063.04c9dbd90KERNEL32.DLL10.0.15063.296ab7aae51c0000005000168501fc401d351d3842662a3C:\WINDOWS\SysWOW64\svchost.exeC:\WINDOWS\System32\KERNEL32.DLLecf12b70-d48e-4c44-8298-bca138a046af
Error: (10/30/2017 05:00:01 PM) (Source: Application Error)(User: )
Description: svchost.exe10.0.15063.04c9dbd90KERNEL32.DLL10.0.15063.296ab7aae51c00000050001685031c401d351d2d12a81bdC:\WINDOWS\SysWOW64\svchost.exeC:\WINDOWS\System32\KERNEL32.DLL4c64e617-33e8-4a8d-8268-574df2b41437
Error: (10/30/2017 04:55:01 PM) (Source: Application Error)(User: )
Description: svchost.exe10.0.15063.04c9dbd90KERNEL32.DLL10.0.15063.296ab7aae51c00000050001685026f001d351d21e314da3C:\WINDOWS\SysWOW64\svchost.exeC:\WINDOWS\System32\KERNEL32.DLL192576f5-4880-409e-826b-33062e7c67e0
Error: (10/30/2017 04:51:05 PM) (Source: Perflib)(User: )
Error: (10/30/2017 04:49:58 PM) (Source: Application Error)(User: )
Description: svchost.exe10.0.15063.04c9dbd90KERNEL32.DLL10.0.15063.296ab7aae51c000000500016850cf401d351d16951e98fc:\windows\syswow64\svchost.exeC:\WINDOWS\System32\KERNEL32.DLL4b9180b8-b076-44b7-9119-8c147af4f067
Error: (10/29/2017 07:24:16 PM) (Source: Application Error)(User: )
Description: svchost.exe10.0.15063.04c9dbd90KERNEL32.DLL10.0.15063.296ab7aae51c000000500016850219401d3511dcd8b3ef2C:\WINDOWS\SysWOW64\svchost.exeC:\WINDOWS\System32\KERNEL32.DLL5fe375a4-96a0-4952-9447-cb4bde774317
Error: (10/29/2017 07:19:16 PM) (Source: Application Error)(User: )
Description: svchost.exe10.0.15063.04c9dbd90KERNEL32.DLL10.0.15063.296ab7aae51c00000050001685033e801d3511d1a91eb79C:\WINDOWS\SysWOW64\svchost.exeC:\WINDOWS\System32\KERNEL32.DLLcc3be45b-f226-48f1-91e3-c419b4b67ef9
Error: (10/29/2017 07:14:16 PM) (Source: Application Error)(User: )
Description: svchost.exe10.0.15063.04c9dbd90KERNEL32.DLL10.0.15063.296ab7aae51c0000005000168501bac01d3511c679b5d98C:\WINDOWS\SysWOW64\svchost.exeC:\WINDOWS\System32\KERNEL32.DLLfb649411-c9af-4608-a46b-ffb45c232dc6
Error: (10/29/2017 07:09:16 PM) (Source: Application Error)(User: )
Description: svchost.exe10.0.15063.04c9dbd90KERNEL32.DLL10.0.15063.296ab7aae51c0000005000168501e2801d3511bb4a44fb4C:\WINDOWS\SysWOW64\svchost.exeC:\WINDOWS\System32\KERNEL32.DLL21550ce7-d1b2-43b3-be7a-37a767ba3843
CodeIntegrity Errors:
Date: 2017-10-30 17:10:47.370
Description: Code Integrity determined that a process (\Device\HarddiskVolume2\Program Files (x86)\Google\Chrome\Application\chrome.exe) attempted to load \Device\HarddiskVolume2\Program Files (x86)\Overwolf\0.107.256.0\x64\OWExplorer.dll that did not meet the Microsoft signing level requirements.
Date: 2017-10-30 17:10:47.367
Date: 2017-10-30 17:10:47.363
Date: 2017-10-30 17:10:47.359
Date: 2017-10-30 17:10:47.353
Date: 2017-10-30 17:10:47.350
Date: 2017-10-30 17:10:45.946
Date: 2017-10-30 17:10:45.943
Date: 2017-10-30 17:10:45.940
Date: 2017-10-30 17:10:45.936
