Update failing? RT-AC68U Merlin 384.19
Not sure of the command line option, but if you really are on a Merlin version of the firmware (not stock Asus), the GUI command for formatting jffs is under Administration, System tab, second box from top. Check the box for format on next boot, hit apply at bottom of page, then reboot the router.
Thank you... I was looking the wrong place for it. It's right where you said it would be.
