Cool_Games
Anyone else seeing this on Verizon FIOS ?
I am seeing a drop in upload speed since updating firmware.
I am able to pass 900 in both directions through the router between two hardwired systems using iperf3 but not to the router.
Running iPerf3 from LAN2 server (...34) to LAN4 client (...80)
Running iPerf3 on router server (...1) to LAN4 client (...80)
If I use ssh and login into the router and run iperf3 on router commad line I get less than 400.
I recently also copied the arm speedtest to the jffs directory to run Ookla speedtest from command line.
Pasted from QoS Internet Speed log history verifies the FIRMWARE is culprit
2021/5/21 768.19 381.26 4.84 0.23 0.00 ComCast Boston
10:27
2021/5/21 715.69 357.98 2.72 0.21 0.00 Starry Boston
Signature Version 2.230 Updated : 2021/05/20 14:21
BEFORE AX82U FW Upgrade to 3.0.0.4.386_43129-g60defb2
2021/5/11 763.42 717.41 4.20 0.43 0.00 Server unrecorded
09:41
2021/5/11 772.33 930.10 3.34 1.07 0.00 ComCast Boston
09:40
$ iperf3 -s
Server listening on 5201
Accepted connection from 192.168.50.80, port 36962
[ 5] local 192.168.50.34 port 5201 connected to 192.168.50.80 port 36964
[ ID] Interval Transfer Bitrate
[ 5] 0.00-1.00 sec 112 MBytes 941 Mbits/sec
[ 5] 1.00-2.00 sec 112 MBytes 941 Mbits/sec
[ 5] 2.00-3.00 sec 112 MBytes 941 Mbits/sec
[ 5] 3.00-4.00 sec 112 MBytes 941 Mbits/sec
[ 5] 4.00-5.00 sec 112 MBytes 941 Mbits/sec
[ 5] 5.00-6.00 sec 112 MBytes 941 Mbits/sec
[ 5] 6.00-7.00 sec 112 MBytes 941 Mbits/sec
[ 5] 7.00-8.00 sec 112 MBytes 941 Mbits/sec
[ 5] 8.00-9.00 sec 112 MBytes 941 Mbits/sec
[ 5] 9.00-10.00 sec 112 MBytes 941 Mbits/sec
[ 5] 10.00-10.00 sec 67.9 KBytes 915 Mbits/sec
[ 5] 0.00-10.00 sec 1.10 GBytes 941 Mbits/sec receiver
Accepted connection from 192.168.50.80, port 36974
[ 5] local 192.168.50.34 port 5201 connected to 192.168.50.80 port 36976
[ ID] Interval Transfer Bitrate Retr Cwnd
[ 5] 0.00-1.00 sec 115 MBytes 967 Mbits/sec 0 1.10 MBytes
[ 5] 1.00-2.00 sec 112 MBytes 944 Mbits/sec 0 1.10 MBytes
[ 5] 2.00-3.00 sec 112 MBytes 944 Mbits/sec 10 889 KBytes
[ 5] 3.00-4.00 sec 111 MBytes 933 Mbits/sec 0 971 KBytes
[ 5] 4.00-5.00 sec 112 MBytes 944 Mbits/sec 0 1.01 MBytes
[ 5] 5.00-6.00 sec 112 MBytes 944 Mbits/sec 0 1.01 MBytes
[ 5] 6.00-7.00 sec 112 MBytes 944 Mbits/sec 0 1.01 MBytes
[ 5] 7.00-8.00 sec 111 MBytes 933 Mbits/sec 0 1.01 MBytes
[ 5] 8.00-9.00 sec 112 MBytes 944 Mbits/sec 0 1.07 MBytes
[ 5] 9.00-10.00 sec 112 MBytes 944 Mbits/sec 0 1.07 MBytes
[ 5] 0.00-10.00 sec 1.10 GBytes 944 Mbits/sec 10 sender
# iperf3 -s
Accepted connection from 192.168.50.80, port 40232
[ 5] local 192.168.50.1 port 5201 connected to 192.168.50.80 port 40234
[ ID] Interval Transfer Bandwidth
[ 5] 0.00-1.00 sec 94.1 MBytes 789 Mbits/sec
[ 5] 1.00-2.00 sec 112 MBytes 937 Mbits/sec
[ 5] 2.00-3.00 sec 56.9 MBytes 478 Mbits/sec
[ 5] 3.00-4.00 sec 92.2 MBytes 772 Mbits/sec
[ 5] 4.00-5.00 sec 111 MBytes 936 Mbits/sec
[ 5] 5.00-6.00 sec 111 MBytes 931 Mbits/sec
[ 5] 6.00-7.00 sec 111 MBytes 933 Mbits/sec
[ 5] 7.00-8.00 sec 112 MBytes 940 Mbits/sec
[ 5] 8.00-9.00 sec 112 MBytes 942 Mbits/sec
[ 5] 9.00-10.00 sec 110 MBytes 921 Mbits/sec
[ 5] 0.00-10.00 sec 0.00 Bytes 0.00 bits/sec sender
[ 5] 0.00-10.00 sec 1023 MBytes 858 Mbits/sec receiver
Accepted connection from 192.168.50.80, port 40248
[ 5] local 192.168.50.1 port 5201 connected to 192.168.50.80 port 40250
[ ID] Interval Transfer Bandwidth Retr Cwnd
[ 5] 0.00-1.05 sec 45.8 MBytes 365 Mbits/sec 0 243 KBytes
[ 5] 1.05-2.05 sec 43.8 MBytes 368 Mbits/sec 0 256 KBytes
[ 5] 2.05-3.05 sec 43.2 MBytes 362 Mbits/sec 0 287 KBytes
[ 5] 3.05-4.03 sec 42.5 MBytes 364 Mbits/sec 0 287 KBytes
[ 5] 4.03-5.04 sec 42.5 MBytes 355 Mbits/sec 0 287 KBytes
[ 5] 5.04-6.06 sec 43.3 MBytes 355 Mbits/sec 0 325 KBytes
[ 5] 6.06-7.03 sec 41.2 MBytes 356 Mbits/sec 0 325 KBytes
[ 5] 7.03-8.05 sec 45.0 MBytes 369 Mbits/sec 0 325 KBytes
[ 5] 8.05-9.03 sec 42.5 MBytes 364 Mbits/sec 0 325 KBytes
[ 5] 9.03-10.02 sec 42.5 MBytes 362 Mbits/sec 0 325 KBytes
[ 5] 0.00-10.02 sec 432 MBytes 362 Mbits/sec 0 sender
[ 5] 0.00-10.02 sec 0.00 Bytes 0.00 bits/sec receiver
$ ssh -p 1124 admin@192.168.50.1 /jffs/ookla-speedtest-1.0.0-arm-linux/speedtest -s 1774
Speedtest by Ookla
Server: Comcast - Boston, MA (id = 1774)
ISP: Verizon Fios
Latency: 3.69 ms (0.02 ms jitter)
Download: 716.36 Mbps (data used: 379.8 MB)
Upload: 423.75 Mbps (data used: 518.7 MB)
Packet Loss: Not available.
Result URL: https://www.speedtest.net/result/c/9e05b68b-4945-4755-a6a8-83247c9e6282
10:27
09:41
09:40
