Upgrade to 374.43, all settings should be cleared?
aurelijusb
Hello,
I'm planning to upgrade my RT-N66U firmware from 374.32 to 374.43 .
Do I need to clear NVRAM and all settings? If to - is it possible to save all settings and then restore it? Or I need to setup everything from scratch ?
I think that big a leap will require a full reset and manual configuration to ensure the best performance from the new firmware.
If you save and restore settings from an old firmware to a new one, you will undo the purpose of the full reset.
It's also advised to forget the network connection on all devices and reconnect them.
