Dingus
Since the update gap is soo huge should I try updating it in small increments?
Or will it simply not matter and I shouldn't worry about a possible brick issue...
I'm concerned because according to the update logs https://github.com/RMerl/asuswrt-merlin/blob/master/Changelog.txt line 676 (Current) Then 639 380.60 Beta 2 (5-July-2016)
IMPORTANT: The firmware image file format was changed by Asus.
Starting with 380.60, you will no longer be able to
flash versions older than 380.60, or Asus versions
older than 3.0.0.4.380_3000.
You can currently downgrade by using Firmware Recovery
mode, but there's no guarantee that this will keep working in the future.
This update change concerns me since the format changed in this update going from 59 to 70 will certainly brick it right?
And this change here line 194
380.67 (16-July-2017)
- NEW: Merged with GPL 380_7743 code, with binary blobs from
7378 for N66U
Also concerns me...
How big of a jump should I go at a time to get my router up to date? I've manually patched some things myself over the years but I've been out of the Merlin update loop for too long and just want a few opinions on the best way to go about updating my routers firmware as it's quite outdated now...
I have the RT-AC66U Asus router and no it's not the A or B model its the one that first came out...
7378 for N66U
Also concerns me...
