MrFahrenheit
Hi all, just wanted to get some confirmation / advice before I commit to something that ends up being an expensive mistake...
I currently have a RT-AC5300 with latest Merlin.
At the moment it's using Mullvad VPN, which on startup gets up to 50Mbps speeds, and that drops to 20Mbps within a couple of days so I have scheduled a router restart.
Recent reading has shown that there might be a way for me to get better speeds and less speed degradation thanks to the newer firmwares supporting Wireguard. What I've understood is, and please correct me if I'm wrong:
My main questions are:
1. Is my above understanding correct?
2. If so, what would be the easiest way to migrate to the new router? I've read on here it's not advisable to try to restore a backup from the AC5300 as it will try to restore too much. Are there any other recent tools that might help?
3. When people are talking about the AX86U - do they mean the base model or the 'Pro'. I read on here that the Pro is the AX6000 in a AX86U body, so is that the one to go for?
Sorry about the long post but I didn't want to waste anyones time by providing insufficient information.
I would really appreciate the help, thanks in advance
- Wireguard is only available on the AX models, so won't work on my AC5300
- There is Wireguard Manager available for older models, but that won't work on the AC5300 kernel i.e. 2.6.36.4brcmarm
- So if I want Wireguard support I need a new AX router
- Out of the AX range the AX86U, AX88U and the AX6000 seem to be well recommended
- Once I get Merlin setup on there I can use that with VPN Director and use Mullvad and attain higher speeds (closer to the 400Mbps that I'm paying my ISP for)
