urgently RT-AX56U modified
Bogdan1989
Hello everyone, I would like you to modify 2 very important things for my RT-AX56U router if possible.
The first is: in the SYSTEM LOG menu section there it records all activity that the ROuter does. They should put On, that is to say, Registration activated and OFF of registration. Disabled, that is, do not write anything in that field there, it does not matter if it shows any error, whatever.
Second improvement is to create entire packages between the standard English language and the country where each of you resides. If I find that I have 2 languages, English and Spanish, in the general language section of the website on the right side as soon as I enter instead of having Chinese there. , French, Korean, etc. Because so many languages should eliminate the translated files and thus the translated package takes up less space, I know it is cumbersome to make each language separately, a standard one that is English and Spanish or Portuguese, but all that have 2 languages, no more than English and Spanish. of residence chosen by each user would be great, so those are improvements for the router, the rest works well for the moment.
Don't ask me how to incorporate a code or whatever, I would like to download the new firmware of the latest and have my prayers done, I don't know anything, I would kindly ask the programmers to do me that favor 2 languages English and Spanish and incorporate in SYSTEM LOG on or off Log register activity..Thanks
Asked and answered
Deleted member 82765​
Guest​
hello mi name is bogdan , I would like when I enter the page of my local router that it be the only language and also in the System Log section a button to deactivate activity log I want to delete all files of other languages, for example Chinese language I do not want it and other languages I would like to keep 3 languages English of all life Spanish and Romanian
This type of help does not offer help, therefore what it says there above is not used and insert that code or script of 2 lines and therefore to me it does make sense that it costs you to load 2 or 3 languages than to load 10 languages the load of data is slower having to load 10 languages than having 3, anyway, as for the SYSTEM LOG, it is not necessary to have it open, you can put this code, for example, I don't know if it is correct, I can't program it
# SYSTEM LOG ON: Enabled
# SYSTEM OFF : Disabled
These are simple codes, I don't know if they have them or if it is correct to put the firmware there and compile it again since if you do it once it is saved forever and you wouldn't have to do it again in terms of the language, if it makes sense to eliminate the rest of languages and the router would not have to load 10 languages, it would only load 3 or 2 and it is easier, it would have more space for the ROM and not take up whoever wanted RT-AX56U English and Chinese language, they would have to download another one from other language sections, I know At first it seems cumbersome but you can create a script that when modifying something, all the files are modified at once and it would be saved. and it would be uploaded to the download server anyway if you want to help me do it if not or I would pay say $50 via paypal to do those 2 things once tested obviously have 2 languages English and Spanish and the system log that can be activated or deactivated and if it works everything is fine or I would give the $50 obio first do the complete firmware and in a few days I would charge and transfer the money
Multiple posts won't make for a different answer. Compile it yourself.
