URL block List
m m.
Is it possible to create a URLs block or allow list and import to the Asus router running the latest Merlin firmware?
I assume you're trying to import to Firewall->URL Filter? There is no such import/export functionality. And even if there was, I'm not so sure using the URL Filter is worth the effort.
Would skynet work for you? Have a read about it in the add-ons forum.
Generally no. There isn't a method in the Firewall > URL Filter section to upload a list of URL's to filter.
Example URL Filter page in Asus-Merlin:
Asus Support document on URL Filter:
One might be able to use URL blocking lists with Asus-Merlin addons or third party programs. Check out Skynet or Diversion or AdGuardHome or Pi-hole to see if they can do what you seek.
Suggest you look into Pi-Hole on R-Pi.
