USB Application Accounts messed up RT-AC86U
ASUS RT-AC86U
Thank you @ColinTaylor - going from 384.18 to 384.19 introduced the problem for me - your instructions worked perfectly & allowed me to just re-add the user.
For any newbie like me - here is a reference to enable ssh on ASUS RT-AC86U: (taken from https://www.htpcguides.com/enable-ssh-asus-routers-without-ssh-keys/)
ASUS Router Simple Local SSH access
Log into the web interface of the Asus Router
Click Administration in the left pane
Click the System Tab
Under SSH Daemon section set Enable SSH to Yes
Set the SSH service port if you don't want to use the standard SSH port (22)
Set Allow SSH password login to Yes
Set Enable SSH Brute Force Protection to Yes
Scroll down and click Apply
After enabling ssh on the router, access the router from a command prompt on a pc with
ssh <your_router_admin_user>@<your.router.ip.address>
enter password, then you'll be at a command prompt where you can enter the instructions (nvram..) from @ColinTaylor
Thank you and ColinTaylor doing a great job on this. I am a newbie and this was my first experience getting under the hood of my RT-AC86 and fixing that stinkin' problem of someone other that the administrator of the router getting into that first slot and gumming up the works. This was my first time on SNB, and it will not be the last as I now know smart cookies like you folks are around for me to learn more about Raspberry's!
Thank you! I noticed this issue after 386.1 upgrade. My additional user account was not authenticating. Upon logging into the UI, I noticed the users were swapped as the original poster noted.
Just want to highlight, the admin password was different when using, nvram get acc_list vs nvram get http_passwd
I initially executed the following, but this did not work:
nvram set acc_num="1"
nvram set acc_list="$(nvram get http_username)>$(nvram get http_passwd)"
nvram set acc_webdavproxy="$(nvram get http_username)>1"
nvram commit
reboot
Luckily, I still had my original session opened where I got the password from nvram get acc_list and use that in the post.
nvram set acc_list="admin>IT3****="
nvram set acc_webdavproxy="admin>1"
nvram commit
reboot
Note - I didn't try inputting the password as clear text. That might work as well.
Thank you very much @ColinTaylor for your advice.
I did this, and my USB Application(Samba) users finally got back into order. Massed-up has been fully restored.
    nvram set acc_num="3"
    nvram set acc_list="admin>r6pKvNcKzSyzqUqqEU3n7tFJIhs1AAU2Q9SpNPp9sDg=<user1>xvkpYKdS46lmIXr9S7SR7A=<nas>mb1FDmQFnzBe2JH9ioY9sYABiriu1HJZO0Qm0r5BvdE="
    nvram set acc_webdavproxy="admin>1<user1>0<nas>0"
    nvram commit
    reboot
This a post #16 make it pretty clear what to do when the passwords are encrypted.
THANK YOU SO MUCH! This worked for me too and I am also grateful!
I have the same problem, but not worked for me because (i think) my admin username has special char (is in the form "abcd-efgh").
So, in /etc/samba/smbpasswd I have abcd▒gh and in the WebUI, sambauser is "abcdgh". I try to write clear text instead $(nvram get http_username) but not working. There is a way to escape special char?
Thanks in advance.
It would be better if you just rename your admin account to something that didn't contain special characters. The router shouldn't have allowed you to use special characters in the first place.
A bit late to the party but I was just able to solve the very same issue on my AC86U (merlin 386.2_4). The admin username had a "-" in the middle and after applying the nvram changes and rebooting, the name was always truncated before the dash. A client connecting to an smb share triggered the message about the corrupt smbpasswd entry. I chose a new admin username and the issue is gone. The old username consisted of a-z and the dash only.
Thanks to all for providing the fix.
Thanks @MissingTwins. I wonder whether the addition of the leading "<" is deliberate or part of the corruption (I suspect the latter).
Perhaps the commands to reset the values should be:
nvram commit
reboot
Tried the commands in post 16. Deleted all the accounts except admin. When I try to add back the accounts the router messages "This table only allows 1 items!" Any insight how to fix this without factory resetting the router? Regards
What router model and firmware version?
What page are you trying to add the account on, Samba, FTP, etc?
RT-AC68U
3.0.0.4.386_43129
Samba Users account list
Same issue as the original post on this topic where the first account became un-editable after an Asus firmware upgrade.
Performed the following instructions per post #16
nvram commit
reboot
Found the SAMBA USB application had cleared all the users except admin.
Tried to reconstruct the user list by adding back the users within the Asus Settings(not via ssh) and received the following message after clicking the + sign.
Sorry, no idea why you're getting that message. Try a different browser or a different PC. Try "incognito/private browsing" mode.
nvram commit
reboot
N.B. Your "admin" account name may only contain letters (upper or lower case) and numbers. If it contains any non-alphanumeric characters the fix above will not work.
A few years later, realized I had the same issue and this came handy today.
Thanks!
Although I use Merlin 386.7_2, I noticed the same problem as OP. System Log - General Log showed several lines like this (original username changed/edited to John Doe):
Sep  4 09:54:49 smbd[15932]:   build_sam_account: smbpasswd database is corrupt!  username John Doe with uid 570576 is not in unix passwd database!
Sep  4 09:54:49 smbd[15932]: [2022/09/04 09:54:49.597804,  0] passdb/pdb_smbpasswd.c:1252(build_sam_account)
And I couldn't remove the corrupt Account/User (= John Doe) from Merlin GUI (USB Application - Network Place (Samba) Share / Cloud), because the buttons "Delete this account" and "Modify this account" were greyed out when the Account/User John Doe was selected.
In addition to this, normally the "Admin" of the router has been on top of the Account/User list. But now this corrupted John Doe was the topmost on the list and could not be removed by me.
My Admin password was the same when using
nvram get acc_list
vs.
nvram commit
reboot
I also run the code as mentioned above by bob49b and which was originally provided by ColinTaylor (post #16). And I also ended up with the result that only the Admin was left on the list. And all other users (6 of them with my setup) were gone.
From "USB Application - Network Place (Samba) Share / Cloud Disk" I have "Maximum number of concurrent connections" set to 6 (for my 6 User Accounts). And I could manually add (= restore) the vanished Accounts. Although it took some time because setting the R/W rights for several users and folders and applying/saving the settings doesn't happen very quickly.
P.S. My Admin username has no non-alphanumeric characters. Only lower and upper case letters.
After reinstalling from a backup, I found out I could not get access the backup folder from the router samba share.
It took me some time to understand my users were switched, the admin user became the back up user and the back up user became the admin user.
user1@RTAX58U:/tmp/home/root# nvram get acc_num
2
user1@RTAX58U:/tmp/home/root# nvram get acc_list
user1@RTAX58U:/tmp/home/root# nvram get http_passwd
user1@RTAX58U:/tmp/home/root# nvram get acc_webdavproxy
user2>0<user1>0
user1@RTAX58U:/tmp/home/root# cat \etc\passwd
cat: can't open 'etcpasswd': No such file or directory
Is this method still valid ? per this thread
nvram unset acc_list
nvram unset acc_webdavproxy
nvram commit
service reboot
nvram commit
service reboot
This does not appear to work reliably anymore. Try this instead:
nvram set acc_num=1
nvram set acc_list="<admin>password"
nvram commit
Where admin is the name of the account you use to log into the router's webUI and password is it's password.
Now refresh the Samba page in the webUI. Hopefully you will have just the admin account showing there and you can now start adding back the additional Samba accounts and permissions.
If you have problems using the Samba admin account in particular try changing your admin password to something different in Administration - System > Router Login Password and then changing it back again.
Indeed, it erased all the accounts but even recreating them, with the same password. I still had username/password errors to access the samba folders.
nvram set acc_num=1
nvram commit
As you said, I just had the admin account correctly named.
And I set another account and permissions anew but still username/password errors trying to access the samba folders.
I'll see if a router reboot will fix those errors.
Thank you.
@bidh See my updated post above.
OK. The updated instructions work. And the last step was important. Thanks a lot.
So the samba share now works with windows and I had to recreate the Synology Active Backup task, but it works.:D
At long last, I just tried to update entware, but failed.
And after restoring a backup carrying that bug, samba shares stopped working.
And that triggered another bug in synology active backup "You do not have permission to access the file on the server".
Now, I hope the next backups won't have that bug.
