For Apple devices? Yes.
Just to make this clear, it's all the same:
Bonjour = Rendezvouz = Zeroconf = Avahi
The problem is Asuswrt starts mt-daapd with '-m' option, which disables mt-daapd's built-in mDNS. Since there is no other mDNS handler in FW, '-m' option is a mistake, probably a relic from the time avahi and mt-daapd had some bug issue due to their twin mDNS function.
Do you know where can I find a startup script for mt-daapd, so I can get rid of '-m' ?
In the long run, Merlin, please remove '-m' from mt-daapd startup script, if you have no plan to add an mDNSResponder daemon to FW.
538 admin 2000 S avahi-daemon: running [RT-AC68U-C958.local]
Asuswrt does have Avahi.
Code:538 admin 2000 S avahi-daemon: running [RT-AC68U-C958.local]
Avahi doesn't appear in the list of running processes on my ac66u and any attempt to start it is met with 'No such file or directory' even though I can see it in usr/sbin.
mt-daapd does appear, initially with the -m command, which I'm assuming, in the absence of avahi, is why the server isn't working.
When mt-daapd is restarted without -m (as seen in process list), the server works perfectly, although, often crashes after a short while.
If any of this is complete rubbish, feel free to correct me, my linux knowledge remains at zero!
I suspect Asus only enables Avahi when also enabling Time Machine (I didn't check the code).
If it were me, I would just remove mt-daapd from the firmware. Aside from the fact that this is yet another proprietary protocol being supported specifically for Apple devices when there are open alternatives such as DLNA and I don't like supporting proprietary protocols, this daemon is also quite old and haven't been actively developed for years by its authors. It's a miracle that it still works at all with modern iTunes releases.
Welcome To SNBForums
