ASUS RT-AX86U Running Merlin 386.5
Every few months my USB drive unmounts, which kills my swap file and takes out Diversion and Skynet, among other things. I've used a few different manufacturer's drives, including Kingston, Memorex, generic, USB2.0, USB3.0, etc. I format the drive in AMTM, etx4 with journaling on, and then create a 2 gig swap file for Entware et al. Runs great for a few months and then the first thing I usually notice is an abundance of ads in my browsers. The log file is riddled with errors pertaining to no swap file and the like and sure enough, running fd in AMTM reports problems with the drive and will not repartition it.
The strange part is that the drive is rendered unusable. I've tried to wipe off the partition, reformat the drive, change file formats, etc but I get a device I/O error and "partition table locked" error no matter what software/OS I try to use. Sometimes it disappears from the router's GUI frontpage, other times it's there but unmountable. The GUI pretends to reformat the drive but doesn't, nothing else even pretends to and I get those errors. Stranger still, I can clone the failed drive to a new drive with Acronis in Windows and when I reboot the router it's as if never happened. I could understand a physical problem and a flat out drive failure but none of the drives ever have read problems or report bad sectors afterwards, and the failure is always identical. Maybe four times now over the last year and a half??
Any ideas? TIA.
Any ideas? TIA.
