I use a USB hard drive enclosure with WD 1TB green drive inside.
After plug in the USB drive it works well. But after long time no access to the hard drive, the USB hard drive stop working and can not be active again.
The USB light on the router is off. On the web GUI, it shows no USB device.
Then I unplug the hard drive power and could make it work again.
I think it's because of the WD green drive went to sleep cause the problem.
I try the stock firmware (v270) and the Merlin firmware (v270b4). They all have the same problem.
Is anybody else have this problem? And how can I fix it or find a work around?
