USB not mounting during soft reboot
  • Thread starter Thread starter Deleted member 62525
  • Start date Start date
D
Guest
Hi
I am the newest firmware RT-AC86U - 384.8_2. I have Diversion 4.0.7, latest amtm and Skynet 6.7.0.
The problem I am experiencing is during soft reboot USB 3.0 is not mounting. I have to do hard boot.
Has anyone have the same issue?
mark
Hi
mark
I haven’t had that happen to me before. Can you try do another soft reboot of the router then run the fdisk-l command to list all the mounted/unmounted attached disks the router is actually detecting. I just want to know if it’s listed there after the soft reboot. The wiki unmount section demonstrates the fdisk -l command and what the output should look like.
https://github.com/RMerl/asuswrt-merlin/wiki/Disk-formatting#5-unmount
