I have a RT-AC86U and when I reboot for an update or just to reboot my USB drive does not get mounted and hence skynet does not start up. I believe this used to work way back (unsure how long ago, but it has been a least a year or two). So if I am on the premises I have to pull the USB drive out and put it back in. Then I manually start skynet. I have a lot of devices that I block from the Internet and this gives them a chance to get out before I do all this. I believe I tried different combinations of USB2 and USB3, but honestly I cannot remember any more. In my upgrade today to 386.3_2 the drive was plugged into the USB 3 port and was set to USB 2 mode. The USB 2 mode is because I thought I read long ago about an issue with USB 3. The USB drive is a Samsung USB 3.1 Bar 32GB.
How can I get the USB drive to automount on reboots? Is there still issues with USB 3 on this firmware/router?
If this is corrected would there still be a time period in which skynet blocked devices could get to the Internet?
