use vpn client in asus rt-ax56u!!
No AES acceleration. The performance is identical to what an RT-AC68U would get if its CPU was running at 1.5 GHz, it's a linear improvement.
Hello,
I get openvpn client working now.
what doing was flashing in that beta from you, after that doing hardware reset install router again.
After that load up an openvpn file from my vpn provider.
working now but two thing my wan port showing red ligth and power not ligtning white
should do an reboot see if will ligth on power
Do you know what equipment currently available on the market has OpenVPN hardware support. I know RT-AC86U and RT-AX88U and some other?
I assume you mean AES acceleration, not OpenVPN support, as these are two very different things.
From Asus, that would be the RT-AX88U, RT-AC86U, GT-AC5300, GT-AX11000, RT-AX92U.
No idea about other manufacturers. From Broadcom, that would be any device based on the BCM4906 or BCM4908. I don't know which Qualcomm SoC supports AES acceleration.
  • Like
Reactions: oem
