Sorry if my last post sounded terse it wasn't meant to cause offence.Ok cool...i'll re-read brother. thank you.
Try this:Is there a way to reset the QOS settings to it default settings without doing a factory reset or exclude it from the restore?
I think the restore mess up Adaptive QoS on the lastest version. The QoS profiles doesn't get apply when I hit apply.
nvram unset qos_rulelist
nvram unset qos_orates
nvram unset qos_irates
nvram unset qos_enable
nvram unset qos_method
nvram unset qos_sticky
nvram unset qos_ack
nvram unset qos_syn
nvram unset qos_fin
nvram unset qos_rst
nvram unset qos_icmp
nvram unset qos_reset
nvram unset qos_obw
nvram unset qos_ibw
nvram unset qos_orules
nvram unset qos_burst0
nvram unset qos_burst1
nvram unset qos_r2q
nvram unset qos_sfql
nvram unset qos_default
nvram unset qos_type
nvram unset qos_bw_rulelist
nvram commit
reboot
A 'clean restore' will only restore values which already exist in NVRAM. This way, if you install a different level, and do a factory reset, the restore won't put back values which are no longer used or which may have been unique to the level where the save was taken.What the difference between "a clean restore" & "restore all values"?
When restoring to same router, same firmware version versus, same router, newer firmware?
When doing a restore on the same level, there is basically no difference (actually, there are a couple of transient values which are different....for example, if you have SAMBA guest access enabled, you'll be prompted again to confirm that you want to allow this if you do a clean restore).
For the general case, it's the safest. In fact, I'm thinking about changing the default restore to a 'clean restore' for the next release.Thank you. So it the best always to do a clean restore"?
We use essential cookies to make this site work, and optional cookies to enhance your experience.
