Using ipset revisited
Just to double check....what does
uname -m
return?
armv7l
Figured out that if I used "--match-set" directly instead of "$MATCH_SET" in the below command, it worked fine.
[ -z "$(iptables-save | grep MicrosoftSpyServers)" ] && iptables -I FORWARD -m set $MATCH_SET MicrosoftSpyServers dst -j DROP
So I added an "echo $MATCH_SET" and it came back blank... but why...
*FIXED
I just manually retyped the below, can't see what was wrong though.
#!/bin/sh
# Different routers got different iptables syntax
case $(uname -m) in
  armv7l)
    MATCH_SET='--match-set'
  mips)
    MATCH_SET='--set'
esac
