Verify NAT Acceleration
knightnz
Apologies if this is a simple query, I've spent an hour searching for an answer and haven't found anything.
How is it possible to verify the form of NAT Acceleration I am currently running under Merlin 384.17 on an AC68U B1 unit?
Sysinfo just shows "HW Acceleration: Enabled" - I'm unsure if this means Flow Acceleration is enabled or not.
Thank you.
If I remember correctly, FA was not supported by the RT-AC66U_B1, only later models.
Bother. I was under the impression that it was any of the variants with the BCM_4709 versus the older 4708. That's a shame.
FA is not a big deal. You can reach 1 Gbps with just CTF.
